产品介绍: |
Supports 45nm Intel Core 2 Quad / Core 2 Duo CPU |
Intel Q45 / ICH10DO support Intel AMT5.0 & vPro |
Four DIMMs up to 8 GB 2-CH DDR2 533/667/800 SDRAM |
Intel® Graphics Media Accelerator 4500 integrated |
Realtek® ALC888 Supports 5.1+2-CH Audio |
Intel® 82567-LM Gigabit LAN |
1 PCI-E 2.0 X16, 1 PCI-E X1, 2 PCI , 1 IDE |
2 COM, 12 USB, 6 SATA/SATA II, 16-bit DIO, 1 LPT |
TPM Ingetraged |
Specifications
| System |
| CPU |
Intel LGA775 socket for Intel Core 2 Quad / Core 2 Duo Processors with Intel 45nm processor technology, TDP 95W |
| FSB |
1333 / 1066 / 800 MHz |
| BIOS |
Award 32 Mb SPI BIOS |
| System Chipset |
Intel Q45 GMCH / ICH10DO |
| I/O Chip |
Winbond W83627DHG-A |
| System Memory |
Four 240-pin DIMM sockets support up to 8 GB Dual Channel DDR2 533/667/800 non-ECC, un-buffered memory |
| Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
| H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats |
| Expansion |
1 x PCI-E 2.0 X16, 1 X PCI-Ex1, 2 x PCI (PCI Rev. 2.3 compliant) |
| S3/S4 |
Yes |
| TPM |
Intel® Integrated TPM1.2 |
| Wake up Mode |
Supports LAN (PXE / RPL) |
| SmartFan Control |
Supports 3 modes in Silent / Optimal / Performance modes |
| I/O |
| MIO |
1 x EIDE, 6 x SATA/SATAII, 2 x RS-232 (5V/12V), 1 x LPT port, 1 x PS2 KB/MS |
| USB |
12 x USB 2.0 |
| DIO |
16-bit DIO (8-bit in and 8-bit out) |
| Display |
| Chipset |
| Display Memory |
Intel® DVMT 4.0 supports up to 352 MB video memory |
| Max. Resolution |
2048 x 1536 @ 32 bpp (75Hz) |
| VGA |
Yes , on board GMA 4500 |
| LVDS |
Through ADD2 LVDS Card |
| DVI |
Through ADD2 DVI Card
| HDMI |
Through ADD2 HDMI Card |
| Secondary VGA |
Through ADD2 VGA Card |
| Audio |
| Audio Code |
Realtek ALC888 high-definition Audio Codec supports 5.1+2-CH two independent Audio streams |
| Audio Interface |
Line-out, Line-in, Mic-in,SPDIF header |
| Ethernet |
| LAN 1 |
Intel® 82567-LM PCI-E Gigabit LAN |
| Back Panel I/O Port |
1 x PS/2 Keyboard / 1 x PS/2 Mouse / 1 x VGA port/ 1 x LPT port / 1 x COM Port / 1 x RJ45 port 4 x USB 2.0/1.1 / 1 x Audio Jack (3 ports) |
| Internal I/O Connector |
4 x USB connectors support additional 8 USB ports 1 x IDE connector 6 x SATA connectors 1 x CPU Fan connector 1 x Chassis Fan connector 1 x Power Fan connector 1 x Front panel header 1 x S/PDIF Out Header 1 x Chassis Intrusion header 1 x 24-pin ATX Power connector 1 x 4-pin ATX 12V Power connector 1 x 4-pin Audio Amplifier |
| Mechanical & Environmental |
| Power Type |
ATX |
| Operating Temperature |
0~50°C (32~122°F) |
| Operating Humidity |
0%~90% relative humidity, non-condensing |
| Size (L x W) |
9.6” x 9.6” (243.84 mm x 243.84 mm) |
| Weight |
1.35 lbs (0.6 Kg) |
| Ordering Information |
MX45Q
Intel Q45 LGA775 Micro ATX Motherboard with VGA, Audio, Gb LAN, 2 COM, 6 SATA, 12 USB, 1 PCI-E2.0 X16, 1 PCI-EX1, 2 PCI, 16-bit DIO |
