产品名称: Micro ATX MX35Q
型  号: MX35Q
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
LGA775 socket for Intel® Core™2 Quad Core™2 Duo Processors with 45nm process technology
FSB
1333 / 1066 / 800 MHz
BIOS
AMI 32 Mb SPI BIOS
System Chipset
Intel® Q35 GMCH / ICH9DO
I/O Chip
Winbond W83627DHG-A
System Memory
Four 240-pin DIMM sockets support up to 8 GB Dual Channel DDR2 800/667/533 SDRAM
H/W Status Monitor
Expansion
One PCI Express X16, one PCI Express X 1, two PCI (PCI Rev. 2.3 compliant)
S3/S4
Yes
TPM
TPM1.2 (Infineon® TPM chip 9635 TT 1.2 on board)
IEEE 1394
LSI FW3227 support 2 IEEE1394 ports
Wake up Mode
LAN mode (PME / RPL)
SmartFan Control
Support 3 modes (Slient/Optimal/Performannce)
I/O
MIO
1 x EIDE 66/100/133, 6 x SATA, 1 x LPT,
1 x RS-232, 1x K/B, 1 x Mouse, 1 x FDD
USB
12 x USB 2.0
Display
Chipset
Intel Q35 GMCH integrated Graphics Media Accelerator 3100
Display Memory
Intel DVMT 4.0 supports up to 384MB video memory
Resolution
2048 x 1536 @ 32 bpp (75Hz)
LVDS
Through ADD2 LVDS Card
DVI
Through ADD2 DVI Card
HDMI
Through ADD2 HDMI Card
Secondary VGA
Through ADD2 VGA Card
Audio
Audio Code
Realtek ALC888 with multiple streaming
Audio Interface
Mic in, Line in, CD Audio in, Line out
Ethernet
LAN1
Intel 82566DM Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard / 1 x PS/2 Mouse / 1 x VGA port
1 x Parallel port / 1 x COM Port / 1 x IEEE1394a
1 x RJ45 port / 4 x USB 2.0/1.1 / Audio Jack (6 ports)
Internal I/O Connector
4 x USB connectors support additional 8 USB ports
1 x Floppy disk drive connector
1 x IDE connector
6 x SATA connectors
1 x CPU Fan connector
1 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
1 x Front panel header
1 x S/PDIF Out Header
1 x Chassis Intrusion header
1 x CD audio inheader
1 x 24-pin ATX Power connector
1 x 4-pin ATX 12V Power connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
9.6” x 9.6” (243.84 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
MX35Q. Intel Q35 LGA775 Core™2 Quad Micro ATX Motherboard with VGA, Audio, Gb LAN, 1 COM, 12 USB, 1 PCI-E x16, PCI-Ex1, 2 PCI, 2 IEEE1394 & TPM
关 键 词: 必升 嵌入式主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
