产品名称: ATX AX45Q3
型  号: AX45Q3
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® LGA775 socket supports Core 2 Quad/
Core 2 Duo/ Celeron® with 45nm process
technology
FSB
1333/ 1066 / 800 MHz
BIOS
Award 32Mb BIOS
System Chipset
Intel® Q45 + ICH10DO Chipset
I/O Chip
Winbond W83627DHG-A
System Memory
Four 240-pin DDR3 DIMM sockets support DDR3
Memories 800/1066MHz up to 8GB
Watchdog Timer
Reset: 1 to 255 sec/min per step
H/W Status Monitor
Monitoring temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
1 PCI-E x 16,
1 PCI-E x 4 (physical with PCI-E x 16 Slot),
1 PCI-E x 1,
4 PCI slots (PCI 2.3 compliant)
GPIO
16-bit General Purpose I/O for 8-bit DI and
8-bit DO
TPM
Integrated iTPM 1.2
Power State
S1, S3, S4, S5
Wake up on LAN or Ring
LAN (PXE)
SmartFan Control
Yes (CPU, SYS & PWR Fan)
Display
Chipset
Intel® Q45 GMCH integrated Graphics Media Accelerator 4500
Display Memory
Intel DVMT 4.0 supports up to 352MB Memory
Max. 3D Resolution
2048 x 1536 @ 75Hz
Dual Display
DVI + VGA
VGA
On board
LVDS
Yes, through ADD2 card
LVDS Backlight Power Connector
Yes, through ADD2-LVDS card
DVI
DVI-I onboard
HDMI
Audio
Audio Codec
Realtek ALC888, 5.1 + 2 CH HD Audio
Audio Interface
Mic-in, Line-in, Line-out
Audio Amplier (W)
3+3W Stereo (TPA3005D2)
Ethernet
LAN 1
Intel® 82567LM LAN Controller (iAMT 5.0)
LAN 2
Intel® 82574L PCI-E x 1 GbE LAN Controller
Back Panel I/O Port
Back Panel I/O Port
2 PS/2 KB+MS,
1 VGA + DVI-D Doube stack,
2 LAN RJ45,
6 USB Ports,
1 eSATA,
Audio I/O (3 jacks)
Internal I/O Connector
1 FDD connector,
1 IDE connector,
5 SATA/SATAII connectors,
3 USB connectors support 6 USB ports,
2 COM header (w/5V or 12V power),
1 CPU Fan connector,
1 System Fan connector,
1 Power FAN connector,
1 Front Audio connector,
1 Audio amplier pin header,
1 S/PDIF connector,
1 CD-in connector,
1 Front panel header,
1 LPT connector,
1 16-bit DIO connector (PH=2.54mm),
1 24-pin ATX Power connector,
1 4-pin ATX 12V Power connector,
1 AT/ATX mode power jumper (3p,2.54mm)
Mechanical & Environmental
Power Requirement
+12V +5V +3.3V 5VSB
3.18A 1.77A 2.85A 0.56A
Power Type
AT/ ATX
Power Connector
1 24-pin ATX Power Connector,
1 4-pin ATX 12V Power Connector
Operating Temperature
0 to 60°C (32 to 140°F)
Operating Humidity
0% to 90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
AX45Q3
90A-Q45006-M0000B2
AX45Q3 R10 ATX LGA775 STD PCK
关 键 词: 必升 嵌入式主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
