Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ATX BV945GR
²úÆ·Ãû³Æ£º ATX BV945GR
ÐÍ ºÅ£º BV945GR
Æ· ÅÆ£º ±ØÉý
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel µFC-LGA 775 socket supports Core 2 Duo/
Pentium D/ Pentium 4/ Celeron D with 65nm
process technology
FSB
1066/800/533 MHz
BIOS
Award 4 Mb Flash ROM BIOS
System Chipset
Intel 945G GMCH/ ICH7R DH
I/O Chip
Winbond W83627EHG-A
System Memory
4 240-pin DIMM sockets support up to 4 GB
Dual Channel DDR2 667/533 SDRAM
Watchdog Timer
KBMS Reset: 1 to 255 sec/min
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
SmartFan Control
Speed Cruise Mode
Expansion
1 PCI-E x16, 1 PCI-E x1, 5 PCI slots
(PCI Rev. 2.2 compliant)
I/O
MIO
2 EIDE (Ultra DMA 100), 4 SATA II, 1 FDD, 1 LPT, 3 RS-232, 1 RS-232/422/485, 1 K/B, 1 Mouse
USB
8 USB 2.0
Display
Chipset
Intel 945G GMCH integrated Graphics Media Accelerator 950
Display Memory
Intel DVMT 3.0 supports 224 MB video memory
Max. Resolution
2048 x 1536 @ 32 bpp (75 Hz)
VGA Interface
PCI-E x16 VGA interface
LVDS
Through ADD2 LVDS Card (Customized BIOS required)
DVI
Through ADD2 DVI Card (Customized BIOS required)
TV-OUT
Through ADD2 TV-Out Card (Customized BIOS required)
Audio
Chipset
Intel ICH7R DH
Azalia Codec
Realtek ALC 888, 5.2 + 2 CH High Definition Audio
Audio Interface
Mic-in, Line-in, CD Audio-in, Line-out, S/PDIF Out
Ethernet
LAN 1
Intel 82573L Gigabit LAN
LAN 2
Back Panel I/O Port
Back Panel I/O Port
1 PS/2 Keyboard
1 PS/2 Mouse
1 Parallel port
1 Serial port
1 VGA port
2 RJ45 ports
4 USB ports
Audio I/O (3 jacks)
Internal I/O Connector
2 USB connectors support additional 4 USB ports
1 24-pin ATX Power connector
1 4-pin ATX 12V Power connector
1 Floppy disk drive connector
2 IDE connector for two devices
3 COM connectors
1 Chassis intrusion connector
1 CD audio in connector
1 TPM connector
4 SATA connectors
1 Front panel audio connector
1 S/PDIF out connector
1 Speaker connector
1 System panel connector
1 3-pin Power LED connector
1 CPU Fan connector
1 Chassis Fan connector
1 Power Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 4.26 A, +12 V @ 10.12 A, +3.3 V @ 722 mA (with Intel Core 2 Duo E6400 2.13 GHz & 2 x 1 GB DDR2 SDRAM)
Power Type
ATX
Operating Temperature
0 to 60¡ãC (32 to 140¡ãF)
Operating Humidity
0% to 90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
BV945GR
Intel LGA775 Core 2 Duo / Pentium D / Pentium 4 / Celeron D ATX Motherboard with VGA, Audio, Dual Gb LAN, 4 COM, 8 USB 2.0, 1 PCI-E x16, 1 PCI-E x1, & 5 PCI
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
