产品名称: ATX AX45Q2
型  号: AX45Q2
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® Q45 LGA775 Socket for Intel® Core™ 2
Quad / Core™ 2 Duo Processors. Support Intel®Next Generation 45nm Multi-Core CPU
FSB
1333/ 1066 / 800 MHz
System Chipset
Intel® Q45 GMCH/ICH10DO
BIOS
AMI 32 Mb BIOS
I/O Chip
Winbond W83627DHG-A
System Memory
Four 240-pin DIMM sockets support up to 8 GB,
DDR3 800/1066
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan
status. Auto throttling control when CPU overheats
Expansion
2 x PCI-E 2.0x16(IDT 24 LAN Switch)
1 x PCI
4 x PCI-Ex1
DIO
16Bit (8 in 8out)
S3/S4
Yes
TPM
Integrated iTPM 1.2
Wake up on LAN or Ring
LAN (PXE / RPL)
SmartFan Control
Yes
Display
Chipset
Intel Graphics Media Accelerator 4500 Integrated
Display Memory
Intel DVMT 4.0 supports up to 384MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (75Hz)
VGA
on board
Audio
Audio Codec
Realtek® ALC888, 5.1 +2 CH with Two Independent Streaming
Audio Interface
Mic-in, Rear Speaker-out
Ethernet
LAN 1
Realtek RTL 8111SC Gigabit LAN
LAN 2
Back Panel I/O Port
Back Panel I/O Port
1 x VGA Port / 4 x USB 2.0/1.1 Port /1 x COM,RS232/422/485 Configured By Jumper Setting /2 x RJ45 Port / 1 x PS2 KB/MS/ 1 x eSATA Port /1 x Audio Jack(Mic in/Line in/Line out)
Internal I/O Connector
*5 x SATA Connectors
*4 x USB Connectors Support Additional 8 USB Ports (with 5V dual)
*1 x COM Header
*1 x CPU Fan Connector
*1 x Chassis Fan Connector
*1 x Power Fan Connector
*1 x Front Panel Header
*1 x Chassis Intrusion Header
*1 x 24-pin ATX Power Connector
*1 x 4-pin ATX 12V Power Connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
AX45Q2
Intel® Q45 LGA775 Core™2 Quad ATX Motherboard with VGA, Audio, Dual Gb LAN,2 COM, 8 USB, 2 PCI-Ex16, 4 PCI-Ex1, 1 PCI,16-bit DIO, iTPM
关 键 词: 嵌入式主板 AX45Q2
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
