产品名称: ATX AX45Q
型  号: AX45Q
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® Q45 LGA775 Socket for Intel® Core™
2 Quad / CoreTM 2 Duo Processors. Support
Intel® Next Generation 45nm Multi-Core CPU
FSB
1333 / 1066 / 800 MHz
BIOS
AMI 32Mb BIOS
System Chipset
Intel Q45 GMCH/ICH10DO
System Memory
Four 240-pin DIMM sockets support up to 8 GB,
DDR2 800 / 667 MHz
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
1 x PCI-E 2.0 x16 / 2 x PCI-E x1/2 x PCI 2.3 32/64bit 33/66MHz (TI Bridge)/2 x PCI 2.3 33MHz (South Bridge)
DIO
16Bit (8 in 8out)
TPM
Intergrated iTPM 1.2
S3/S4
Yes
Wake up on LAN or Ring
LAN (PXE / RPL)
SmartFan Control
Yes
Display
Chipset
Intel Q45 GMCH integrated Graphics Media
Accelerator 4500
Display Memory
Intel DVMT 4.0 supports up to 384MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (75Hz)
VGA
on board
Audio
Audio Codec
Realtek ALC888, 5.1 +2 CH with Two Independent Streaming
Audio Interface
Mic-in, Rear Speaker-out
Ethernet
LAN 1
Realtek RTL 8111SC Gigabit LAN
LAN 2
Back Panel I/O Port
Back Panel I/O Port
1 x VGA port / 1 x COM port(RS-232/422/485)/2 x RJ45 port / 4 x USB 2.0/1.1 port/1 x eSATA port / 1 x Audio Jack (2 port) / 1 x PS2 KB/MS
Internal I/O Connector
*5 x SATA connectors
*4 x USB connectors support additional 8 USB ports (with 5V dual)
*1 x COM header(RS-232/422/485)
*1 x CPU Fan connector
*1 x Chassis Fan connector
*1 x Power Fan connector
*1 x Front panel header
*1 x Chassis Intrusion header
*1 x 24-pin ATX Power connector
*1 x 4-pin ATX 12V Power connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
AX45Q
Intel Q45 LGA775 CoreTM2 Quad ATX
Motherboard with 1 x PCI-E 2.0 x16, 2 x PCI-E x1,4 x PCI 2.3, 2 x COM, 12 x USB 2.0,4 x SATA/SATAII, 1 x eSATA, 16-bit DIO, & iTPM
关 键 词: 嵌入式主板 AX45Q
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
