²úÆ·Ãû³Æ£º
ATX AX35Q
ÐÍ ºÅ£º
AX35Q
±ØÉý
Supports 45nm Intel Core™2 Quad series Processors |
Intel Q35 + ICH9DO Chipset |
Four DIMMs up to 8 GB 2-CH DDR2 800 SDRAM, non-ECC |
Intel Graphics Media Accelerator 3100 |
Realtek ALC888 Supports 5.1+2-CH Dual Audio Streams |
Dual Realtek RTL8111C Gigabit LAN |
1 PCI-E x16, 1 PCI-E x1, 5 PCI |
4 COM (5/12V), 12 x USB, 6 x SATA II, 1 x IDE |
TPM 1.2, 16-bit DIO |
Specifications
System |
CPU |
LGA775 socket supports Intel Core™2 Quad Core™2 Duo Processors with 45nm process technology |
FSB |
1333 / 1066 / 800 MHz |
BIOS |
AMI 16Mb SPI BIOS |
System Chipset |
Intel Q35 GMCH / ICH9DO |
I/O Chip |
Winbond W83627DHG-A |
System Memory |
Four 240-pin DIMM sockets support up to 8 GB Dual Channel DDR2 800/667 SDRAM, non-ECC |
Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats |
Expansion |
One PCI Express X16, one PCI Express X 1, Five PCI (PCI Rev. 2.3 compliant) |
S3/S4 |
Yes |
TPM |
TPM1.2 (Infineon TPM chip 9635 TT 1.2 on board) |
Wake up Mode |
LAN mode (PME / RPL) |
SmartFan Control |
Support 3 modes (Slient/Optimal/Performannce) |
I/O |
MIO |
1 x EIDE 66/100/133, 6 x SATA II, 1 x LPT, 1 x FDD, 4 x RS-232 (5V/12V output) , 1x K/B, 1 x Mouse |
USB |
12 x USB 2.0 |
e-SATA |
16 bit DIO (8-in/8-out by PCA9555) |
Display |
Chipset |
Intel Q35 GMCH integrated Graphics Media Accelerator 3100 |
Display Memory |
Intel DVMT 4.0 supports up to 284MB video memory |
Max. 3D Resolution |
2048 x 1536 @ 32 bpp (75Hz) |
VGA |
on board GMA 3100 |
HDMI |
Through ADD2 HDMI Card |
LVDS |
Through ADD2 LVDS Card |
DVI |
Through ADD2 DVI Card |
Secondary VGA |
Through ADD2 VGA Card |
Audio |
Audio Codec |
Realtek ALC888 w/o Multiple streaming or 5.1+2-CH multiple streamings HD Audio |
Audio Interface |
Mic in, Line in, CD Audio in, Line out |
Audio Amplifer |
Dual 6W AMP (TPA3005D2, Optional) |
Ethernet |
LAN 1 |
Realtek RTL8111C PCI-E Gigabit Ethernet Controller |
LAN 2 |
Back Panel I/O Port |
1 x PS/2 Keyboard / 1 x PS/2 Mouse / 1 x VGA port/ 1 x Parallel port / 1 x COM Port / 2 x RJ45 port/ 4 x USB 2.0/1.1 / Audio Jack (3 ports) |
Internal I/O Connector |
* 4 x USB connectors support additional 8 USB ports (with 5V dual) * 1 x Floppy disk drive connector * 1 x IDE connector * 6 x SATA connectors * 1 x CPU Fan header (support PWM & DC fan) * 1 x Chassis Fan header (support DC fan only) * 1 x Power Fan |
Mechanical & Environmental |
Power Type |
ATX |
Operating Temperature |
0~60¡ãC (32~140¡ãF) |
Operating Humidity |
0%~90% relative humidity, non-condensing |
Size (L x W) |
12" x 9.6" (304.8 mm x 243.84 mm)
Weight |
1.32 lbs (0.6 Kg) |
Ordering Information |
Intel Q35 LGA775 Core™2 Quad ATX Motherboard with VGA, Audio, Dual Gb LAN, 4 COM, 12 USB, 1 PCI-Ex16, 1 PCI-Ex1, 5 PCI, TPM, 16-bit DIO & 6W AMP |
