System |
CPU |
Onboard Intel® AtomTM N450 SC/ D410 SC/ D510 DC 1.6GHz Processor |
FSB |
DMI (2.5Gbps) x 4 Lanes |
BIOS |
AMI/Legacy 16 Mb SPI BIOS |
System Chipset |
Intel® ICH8M |
I/O Chip |
Winbond W83627DHG-A |
System Memory |
One 200-pin SODIMM socket supports up to 2GB DDR2 800MHz(D510)/ 667MHz (D410/ N450) SDRAM |
Watchdog Timer |
Reset: 1 to 255 sec/min per step |
H/W Status Monitor |
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats. |
Expansion |
1 Mini PCI-E, 1 CF |
Power State |
S1, S3, S4, S5 |
TPM |
Onboard TPM 1.2 by Infineon SLB9635 (optional) |
Wake up on LAN or Ring |
LAN (PXE), Ring (COM 1/2) |
SmartFan Control |
Supports 3 modes (Silent/Optimal/Performance) |
I/O |
MIO |
2 SATA II, 2 COM RS-232, 1 PS/2 Keyboard, 1 PS/2 Mouse |
USB |
6 USB 2.0 |
GPIO |
8-bit General Purpose I/O for 4-bit DI and 4-bit DO |
Display |
Chipset |
Integrated Intel® Gen3.5+GFX Render Core 200MHz (N450/D410)/400MHz (D510) |
Display Memory |
Shared Memory Max 224MB |
Max. Resolution |
LVDS : Max 1280 x 800 or 1366 x 768 VGA : Max 2048 x 1536 @ 60Hz |
Dual Display |
LVDS+VGA |
VGA |
On board |
LVDS |
18-bit Single Channel LVDS |
LVDS Backlight |
5V and 12V |
Audio |
Audio Codec |
Realtek ALC888, 5.1 + 2 CH HD Audio |
Audio Interface |
Line-in, Line-out, Mic-in |
Ethernet |
Ethernet |
Realtek RTL8111C Gigabit LAN |
Back Panel I/O Port |
1 PS/2 Keyboard+Mouse, 1 VGA Port, 1 LAN RJ45 Port, 2 USB 2.0 Ports, 1 Line-out, 1 12V DC-in |
Internal I/O Connector |
2 COM RS-232 Ports w/ Power, 1 CPU Fan Connector, 1 Front Panel Header supports 2 USB Ports, 1 USB Connector supports 2 USB Ports, 1 18-bit LVDS Connector, 1 LVDS Invertor Connector, 2 SATA II Connectors, 1 CF Socket (on the back), 1 Digital I/O Header, 1 Mic-in & Line-in Header, 1 Mini PCI-E |
Mechanical & Environmental |
Power Requirement |
+12V (3A) |
Power Connector |
12V CPU Fan Connector |
Operating Temperature |
0 to 60¡ãC (32 to 140¡ãF) |
Operating Humidity |
0% to 90% relative humidity, non-condensing |
Size (L x W) |
4.72¡± x 4.72¡± (120 mm x 120 mm) |
Weight |
0.31 lbs (0.13Kg)/ 0.5 lbs (0.24Kg) with Fan |
