产品名称: Nano ITX NX15MXL2
型  号: NX15MXL2
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel Atom processor Z510P 1.1GHz/Z530P 1.6GHz
FSB
400/533 MHz
BIOS
Award 8 Mb FHW BIOS
System Chipset
Intel System Controller Hub US15WP
System Memory
One 200-pin SO-DIMM 2 GB DDR2 400/533 org.x16 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage status. Auto throttling control when CPU overheats
Expansion
2 x Mini PCI-E
DIO
2 x DI, 2 x DO
S3/S4
S3/S4/Never Sleep
Display
Chipset
Intel® System Controller Hub US15WP
Display Memory
Intel® Graphics Media Accelerator 500
(Intel® GMA 500)
Max Resolution
LVDS Display : 1366 x 768 @85 MHz
Ext Display: 1920x1080 @ HDMI-to-HDMI
1440x1050 @ HDMI-to-DVI
Dual Display
Yes , LVDS+HDMI
LVDS
Yes, 18 or 24 bit Single Channel
LVDS Backlight Power
Yes
HDMI
Supported
Audio
Audio codec
Realtek ALC 888 7.1 channel HD
Audio Interface
Line-Out & Mic.-In
Internal I/O Connector
* 1 x USB connectors support 2 USB ports
* 1 x 12V DC Power in pin header
* 1 x LVDS connector
* IDE connector
* Mic in/Line out
* 1 x HDMI
* 1 x GPIO connector
Mechanical & Environmental
Power Requirement
36W
Power Type
12V DC-in with power button and LED pin header
Operating Temperature
0-60°C(32-104°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
120 mm x 70 mm
Weight
0.15 lbs(70g)
Ordering Information
NX15MXL2
Intel Atom processor Z510P 1.1GHz/Z530P 1.6GHz 2.5" Motherboard with ,LVDS, HDMI,Audio, Mini PCIe, 1 PATA,
2 USB & 4-bit DIO
关 键 词: 嵌入式主板 NX15MXL2
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
