产品名称: Nano ITX NX15MXL
型  号: NX15MXL
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® Atom™ processor Z510P 1.1GHz/Z530P 1.6GHz
FSB
400/533 MHz
BIOS
Award 8 Mb FHW BIOS
System Chipset
Intel® System Controller Hub US15WP
I/O Chip
Winbond W83627DHG
System Memory
1 x 200-pin SODIMM 2 GB DDR2 400/533 org.x16 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
1 x Mini PCIe/1 x CF
Wake up on LAN/Ring
8-bit General Purpose I/O for 4 DI and 4 DO
S3/S4
Yes
Wake up on LAN or Ring
Both (PXE / RPL )
SmartFan Control
Chassis Fan
Display
Chipset
Display Memory
Intel® Graphics Media Accelerator 500
(Intel® GMA 500)
Max Resolution
LVDS Display : 1366 x 768 @85 MHz
Ext Display: 1280 x 1024 @ 85 Hz maximum resolution
Dual Display
Yes , LVDS+VGA
VGA
Yes
LVDS
Yes, 18/24 bit Single Channel
LVDS Backlight Power
Yes
Audio
Audio Codec
Realtek ALC 888 (co-lay ALC 888VC)
Audio Interface
Mic in , Line out ( 2 jack ) , Line in pin header
Ethernet
LAN 1
Realtek RTL 8111C Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
1X PS2(KB+MS) / 1 x VGA port / 2 x USB 2.0/1.1
/1 x LAN RJ45 port / 1 x Audio Mic in (1 jack)
/1 x Audio Line out (1 jack)
Internal I/O Connector
* 1 x USB connectors support additional 2 USB ports
* 1 x 6-pin ATX Power connector
* 1 x COM port pin header
* 1 x LVDS connector
* 1 x Chasis FAN connector
* 1 x GPIO connector
* 1 x PATA interface
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0-60°C(32-104°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
4.72" x 4.72" (120 mm x 120 mm)
Weight
0.3 lbs(0.14Kg)
Ordering Information
NX15MXL
Intel Atom™ processor Z510P 1.1GHz/Z530P 1.6GHz Nano ITX Motherboard with VGA,LVDS,Audio, LAN, Mini PCIe, CF, 1 COM, 1 PATA,4 USB & 8-bit DIO
关 键 词: 嵌入式主板 NX15MXL
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
