²úÆ·Ãû³Æ£º
Embedded PC ELF-310
ÐÍ ºÅ£º
ELF-310
±ØÉý
Fanless design |
Mini-Volume & Light Weight |
4 x USB 2.0 Ports |
1 x RS-232 COM port |
1 x 4-In/4-Out GPIO |
1 x Gigabit LAN |
1 x mini-PCI expansion slot |
XP Embedded |
Support VESA mount |
Specifications
System |
CPU |
VIA C7 1.5GHz/Eden ULV 1GHz |
Chipset |
VIA CX700M |
Memory |
1 SO-DIMM , DDR2-400/533 Up to 1 GB |
Storage |
1 x CF |
External I/O |
Rear Panel |
12V DC-In , PS/2 Keyboard& Mouse , CRT , 2 x USB , Mic-In and Line-Out , Wireless LAN (Optional) |
Front Panel |
2 USB , 1 COM , 1 GPIO (4-in,4-out) |
LAN |
Gigabit LAN |
Button |
Power |
LED |
HDD , Power |
VGA |
x1 |
Antenna |
b/g/n (Optional) |
Power Supply Unit |
Power Input |
100 ~240 V / 50 ~ 60 Hz (PSU) |
Power Output |
19V , 65W DC-In |
Operating Software |
Microsoft |
barebone or XP embedded |
Mechanical & Environmental |
Operating Temperature |
0¡ãC ~ 45¡ãC(32~113¡ãF) |
Relative Humidity |
0%~90%, non-condensing |
Mounting |
VESA Mount(optional) |
Dimensions(WxHxD) |
160x147x42 mm |
Weight |
1Kg |
Ordering Information |
ELF-310
90D-ELF310-1000000, ELF-310 Performance Oriented Fanless BOX | |
