Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Embedded PC ECX331
²úÆ·Ãû³Æ£º Embedded PC ECX331
ÐÍ ºÅ£º ECX331
Æ· ÅÆ£º ±ØÉý
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
Expansion
Add-on Card
1 x PCIe Full-height / half-length slot
Hark Disk Drive
1 x 2.5" HDD (Internal, IDE/SATA)
SSD
1 x Type I/II CF slot on bottom
External I/O
Rear Panel
Depends on system Motherboard
Front Panel
1 x PWR SW, 2 x USB, 2 x LED (PWR/HDD)
Optional Knock-out
2 x COM
Power Supply Unit
Power Input
100 ~240 V / 50 ~ 60 Hz (Adapter)
Power Output
200 W
Mechanical & Environmental
Operating Temperature
0~40¡ãC (32~104¡ãF)
Relative Humidity
5 to 90% @ 40¡ãC (104¡ãF), non-condensing
I/O Shield
Standard ATX I/O opening
Mounting
Desk / Wall (wall-mount bracket in option)
Weight
7.71 lbs / 3.5 Kgs
Dimensions (WxHxD)
W300 x H72 x D220 mm
W350 x H84 x D220 mm (w / bracket)
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
