²úÆ·Ãû³Æ£º
Embedded PC FCX230
ÐÍ ºÅ£º
FCX230
±ØÉý
Fanless System Supports up to Intel® Core 2 Duo Processor |
Scalable with More Mini-ITX Options |
Default LVDS / DVI, LAN, CF
Default 5.1+2-CH / 5.1-CH Audio, 6W AMP |
1 x 2.5" HDD |
2 COM, 6 USB |
90W Adapter & Cable Fastener
Optional Knock-out for 1 COM
Fanless Operation |
Specifications
Expansion |
Hard Drive Bay |
1 x 2.5" HDD (Internal, IDE/SATA) |
SSD |
One Type I/II CF slot on bottom |
External I/O |
Rear Panel |
Depends on system Motherboard |
Front Panel |
1 x PWR SW, 2 x USB, 2 x LED (PWR/HDD) |
Optional Knock-out |
1 x COM |
Power Supply Unit |
Power Input |
100 ~240 V / 50 ~ 60 Hz (Adapter) |
Power Output |
12 Vdc / 19 ~ 24 Vdc, 65 / 90 W to system |
Mechanical & Environmental |
Operating Temperature |
0~40¡ãC (32~104¡ãF) |
Relative Humidity |
5 to 90% @ 40¡ãC (104¡ãF), non-condensing |
I/O Shield |
Standard ATX IO opening |
Mounting |
Desk / Wall (wall-mount bracket in option) |
Dimensions (WxHxD) |
W230 x H75 x D235 mm W272 x H87 x D235 mm (w/Bracket) |
