产品名称: VGA Card AD-8001
型  号: AD-8001
品  牌: 必升
· Onboard AMD M72-CSP128 GPU
· On Chip128MB Graphics Memory
· Onboard VGA, DVI-I, S-Video connectors
· Optional Dual VGA Displays
· Low-profile form factor
· Supports DirectX 10, OpenGL 2.0, Shader Model 4.0
· Supports HDMI (Optional)
System
GPU
AMD M72-CSP128
Bus Type
PCI Express x 16
Graphics Memory
128 MB DDR3 on chip (2 pcs of 16M x 32-bit)
Core Clock
600 MHZ
Memory Clock
700 MHZ
Multimedia
Resolution
2048 x 1536 @ 85Hz
Dual Display
LP: VGA+TV-Out, DVI-I + TV-Out
ATX: VGA/TV-Out+DVI-I+LVDS,VGA/TV-Out+VGA+LVDS+HDMI(optio nal)
Output Connectors
VGA1/DVI-I, VGA2, TV-out
HMDI
By cabling connector on ATX bracket (optional)
LVDS
LVDS 24Bit Dual Channel
DVI
Default single DVI
TV-out
S-Video
Primary VGA
Co-layout with DVI-I
Secondary VGA
HD Audio
Integrated with HDMI cable (optional)
Mechanical & Environmental
Power Requirement
25W
Bracket Connectors
Card Form Factor
Low Profile
Bracket Form Factor
ATX
Card Size (L x W)
167.6 mm x 68.9 mm(Low-Profile PCI-E)
System Requirements
Hardware
PCI Express compliant motherboard
Compatible OS
Windows XP and XP x64, Windows 2000, Windows Vista (XDDM) and Vista x64 (XDDM)
Graphics API
DirectX 10 and DX9
Open GL 2.0 support
Shader Model 4.0
关 键 词: 必升 AD-8001
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
