Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Compact Flash Card
²úÆ·Ãû³Æ£º Compact Flash Card
ÐÍ ºÅ£º
Æ· ÅÆ£º ±ØÉý
Compact Flash Card
¡¤ Capacity 1 GB ~ 16 GB
¡¤ Supports SLC (single level cell) NAND Flash Memory
¡¤ Supports PIO Mode 6 / Multi Word DMA Mode 2 / Ultra DMA Mode 5
¡¤ Supports Security ID & S.M.A.R.T.
Capacity
1 G/ 2 G/ 4 G/ 8 G/ 16 GB
Compatibility
CF 3.0, PC Card, Socket¡¯s Services
Form Factor
CF Type-I
Voltage
3.3 V / 5.0 V
Data Transfer Mode
PIO Mode-6
MWDMA Mode-2
UDMA Mode-5
Sustained R/W Performance
2 channel: 43/30 MB per second
1 channel: 22/15 MB per second
Operation Temperature
Commercial Grade: 0 to +70¡ã C
Extended Grade: -40 to +85¡ã C
Host interface
8/16 bit access
ECC (BCH)
Correct up to 6/12 random bits/sector
MTBF
>1,000,000 hours
Vibration resistance
16.5 G
Shock resistance
1,100 G (0.5 msec)
Security Feature Set
Security Disable Password
Security Erase Prepare
Security Erase Unit
Security Freeze Lock
Security Set Password
Security Unlock
Software Spec.
1.
Product key protected GUI Management Tool
2.
GUI Management Tool User Interface
3.
Encrypted Application Programming Interface (API) support
4.
Security ID Read/Write and protecting sample code generator
5.
Get S.M.A.R.T. attribute
Ordering Information
CF1G/ 968EMS0037/ BCM CFCard 1G CF NR, DMA (0~70¡ãC)
CF2G/ 968EMS0038/ BCM CFCard 2G CF NR, DMA (0~70¡ãC)
CF4G/ 968EMS0039/ BCM CFCard 4G CF NR, DMA (0~70¡ãC)
CF8G/ 968EMS0040/ BCM CFCard 8G CF NR, DMA (0~70¡ãC)
CF16G/ 968EMS0041/ BCM CFCard 16G CF NR, DMA (0~70¡ãC)
CF1G-E/ 968EMS0042/ BCM CFCard 1G CF NR, DMA (-40~85¡ãC)
CF2G-E/ 968EMS0043/ BCM CFCard 2G CF NR, DMA (-40~85¡ãC)
CF8G-E/ 968EMS0045/ BCM CFCard 8G CF NR, DMA (-40~85¡ãC)
CF16G-E/ 968EMS0046/ BCM CFCard 16G CF NR, DMA (-40~85¡ãC)
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
