Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Airsense¶þÑõ»¯Ì¼Ä£¿éK30-STA
²úÆ·Ãû³Æ£º Airsense¶þÑõ»¯Ì¼Ä£¿éK30-STA
ÐÍ ºÅ£º K30-STA
General Performance:
Storage Temperature Range ................-30 to +70 ¡ãC
Sensor Life Expectancy ........................> 15 years
Maintenance Interval ............................no maintenance required
Self-Diagnostics ...................................complete function check of the sensor module
Warm-up Time .....................................¡Ü 1 min
Operating Temperature Range ............0 to 50 ¡ãC
Operating Humidity Range ...................0 to 95% RH (non-condensing)
Operating Environment ........................Residential, commercial, industrial spaces and Potentially dusty air ducts used in
                                                            HVAC (Heating Ventilation and Air-Conditioning) systems.
Electrical / Mechanical:
Power Input...........................................4,5-14 VDC, stabilized to within 10% (external protection circuits required)
Current Consumption ............................40 mA average
                                                             < 150 mA peak current (averaged during IR lamp ON, 120 msec)
                                                             < 300 mA peak power (during IR lamp start-up, the first 50 msec)
Electrical Connections ........................terminals not mounted (G+, G0, OUT1, OUT2, Din1, Din2, Status, TxD, RxD)
Dimensions ........................................5,1 x 5,7 x 1,4 cm (Length x Width x approximate Height)
CO2 Measurement:
Sensing Method ....................................non-dispersive infrared (NDIR) waveguide technology with ABC
                                                              automatic background calibration algorithm
Sampling Method ..................................diffusion
Response Time (T1/e) ...........................20 sec diffusion time
Measurement Range ............................0 -5 000 ppmvol
Sensitivity..............................................¡À 20 ppm ¡À 1 % of measured value
Accuracy .............................................¡À 30 ppm ¡À 5 % of measured value
Pressure Dependence...........................+ 1.6 % reading per kPa deviation from normal pressure, 100 kPa
On-board calibration support.................Din1 switch input to trigger Background Calibration @ 400 ppm CO2
                                                               Din2 switch input to trigger Zero Calibration @ 0 ppm CO2
Linear Signal Outputs:
D/A Conversion Accuracy......................¡À 2 % of reading ¡À 20 mV
OUT1 D/A Resolution.........................10 mV
              Linear Conversion Range ........0 -4 VDC for 0 -2 000 ppm  vol.
             Electrical Characteristics...........ROUT < 100 ¦¸, RLOAD > 5k¦¸ , Power input > 4,5 V
OUT2 D/A Resolution.........................5 mV
Linear Conversion Range ........1 -5 VDC for 0 -2 000 ppmvol.
Electrical Characteristics...........ROUT < 100 ¦¸, RLOAD > 5k¦¸ , Power input > 5,5 V
Digital Outputs:
    Electrical Characteristics High Output level in the range 2.3V min to DVDD = 3.3V. (1 mA source)
                                ............................. Low output level 0.75V max (4 mA sink). Protection 56R resistor in series.
             Function .................................. High level at CO2 High
 OUT3, CO2 High Alarm /Reset Level ... 800/700 ppm
OUT4, CO2 High Alarm /Reset Level ... 1000/900 ppm
UART Serial com port:
Protocol ...............................................MODBUS open protocol, refer specification and registers definitions
Hardware interface ...............................CMOS UART with RxD, TxD
Rate                                                  ......9600
, -ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-fareast-font-family: TTE1A77E90t00">              Linear Conversion Range ........0 -4 VDC for 0 -2 000 ppm  vol.
Digital Outputs:
Rate                                                  ......9600
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÊÀ¾æ¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 28232909 / ÃÉÕý¾Ù
ÊÖ»ú£º 13760446073
µØ Ö·£º ÉîÛÚÊÐÁú¸ÚÇøÛàÌï½ÖµÀ»·³ÇÄÏ·3ºÅ½ð·½»ªÎïÁ÷Ô°3¶°215
ÓÊ ±à£º 518131
Ö÷ Ò³£º http://www.sekuo.com
  • Metrodyne ѹÁ¦´«¸ÐÆ÷MPS-5000
  • Airsense¶þÑõ»¯Ì¼Ä£¿éK30-STA
  • MetrodyneѹÁ¦´«¸ÐÆ÷MPS2100
  • CPS120¸ß¶È¼ÆÓõçÈÝʽ´óÆøÑ¹Á¦´«¸ÐÆ÷
  • ѹÁ¦´«¸ÐÆ÷FGN-607PGSR
  • Ô­×°ÏÖ»õ¹©Ó¦Êý×ÖÊä³ö´«ÉùÆ÷¹èßä
  • ¹èßä MEMS¹èMIC ¹èÂó¿Ë·ç
  • ¸ß¶È¼ÆÓÃѹÁ¦´«¸ÐÆ÷SS103
  • Ö¸ÄÏÕë´«¸ÐÆ÷SMC01
  • ѹÁ¦´«¸ÐÆ÷MS5540C
