Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ñʽµ¼µç»¬»·
²úÆ·Ãû³Æ£º ñʽµ¼µç»¬»·
ÐÍ ºÅ£º PSR-CS
PSR-Cs
ñʽµ¼µç»¬»·
ñʽµ¼µç»¬»·ÊÇ¿ÇÌ帽ÓÐÔ²Ðη¨À¼µÄһϵÁе¼µç»¬»·µÄͳ³Æ£¬Ö÷ÒªÓÃÓÚ´«Ê侫ÃÜÐźţ¬Î¢ÈõµçÁ÷£»¾ßÓеÍŤ¾Ø£¬µÍËðºÄÃâά»¤£»µÍµçÆøÔëÒôµÈÖ÷ÒªÌØµã£»
PSR-Csñʽµ¼µç»¬»·ÊÇһϵÁбê×¼²úÆ·£¬²ÉÓýô´ÕÐÍÉè¼Æ£¬½Ó´¥²ÄÁÏʹÓýð£»ÕëʽµçË¢ºÍVÐ͵¼µç»·Éè¼Æ£¬±£³Ö¶àµãÎȶ¨½Ó´¥£¬ÊÇ»¬»·ÓÅÔ½ÐÔÄܵĻù±¾±£Ö¤£»
PSR-Cs°üº¬PSR-C6£¬PSR-C12£¬PSR-C15£¬PSR-C24ËĿµç»¬»·»ù±¾Ðͺţ¬Ìṩ6·£¬12·£¬15·£¬24·´«Êäµç·£»²¢Óжà¿îÍâÐÍÑùʽ¿É¹²Ñ¡Ôñ£¬»ò¿É¸ù¾Ý¿Í»§ÐèÇó¶¨ÖÆÍâÐÍ£»
The PSR-Cs slip ring capsule is a standard, off-the-shelf series product, that uses gold contacts at the rotary interface. Color-coded lead wires are used on both the stator and rotor for simplified electrical connections.
Using a 90o V-groove ring design for each ring, the PSR-Cs provides smoother running, lower torque low contact wear rates than competitive slip ring. PSR-Cs include PSR-C6, PSR-C12, PSR-C15,PSR-C24 slip ring model, provides 6, 12,15, 24 circuit configurations.
1
ÌØÐÔ Feature
½ô´Õ»¯Éè¼Æ£¬Ð¡Ìå»ý£¬Âú×ã¿Á¿Ì¿Õ¼äÐèÇó
Compact miniature design, small size fit for harsh space
Ä£¿é»¯Éè¼Æ£¬Âú×ã¸ü¸ßµçÁ÷£¬×ªËÙ£¬ÍâÐεÈÐèÇó
Moudle design; Meet the most of  requirement
¶àÑù»¯ÍâÐΣ¬Ö§³Ö¸ü¶à°²×°ÒªÇó
More install method for option
Ö§³ÖÐźţ¬µçÔ´¼°Æä»ìºÏ´«Ê䣻
Can combine signal and power in same slip ring
PSR -  C        6   -   A
²úÆ·´úÂë
ϵÁдúÂë
ͨ·Êý
ÍâÐÍÑùʽ
¿ÉÑ¡Ôñ   ͨ·Êý
6
¿ÉÔñÍâÐÍÑùʽ
A
12
B
15
C
24
D
E
2
²ÄÁϼ°Åä¼þ Material and Parts
¿ÇÌå²ÄÁÏ
¹¤³ÌËÜÁÏ
House
Engineering Plastics
½Ó´¥²ÄÁÏ
¹ó½ðÊô£º½ð-½ð
Contact material
Precious: Gold-Gold
µ¼Ïß
12É«AWG#28 Teflon¸ßε¼Ïß
Lead Wire
12color #28AWG Teflon
 wire
Öá³Ð
¾«ÃܹöÖéÖá³Ð
Bearing
Precision ball bearings
Á¬½ÓÆ÷
¸ù¾Ý¿Í»§ÐèÇó£¬ÅäÖÃÁ¬½ÓÆ÷
Connector
BY customer requirement
3
µçÆøÐÔÄÜElectrical Spec.
¶î¶¨µçѹ
240VAC
Rating voltage
240VAC
¶î¶¨µçÁ÷
2A/·,²¢ÁªÖ§³Ö5A,10A
Rating current
2A /Ring, 5A,10A by combined
¾øÔµµç×è
1000MΩ@500VDC
Insulation resistance
1000MΩ@500VDC
ÄÍѹ
600VDC@50Hz
Dielectric strength
600VDC@50Hz
µçÆøÔëÒô
10mΩ@6VDC,50mA, 5Rpm
Electrical noise
4
»úеÐÔÄÜMechanical Spec.
תËÙ
300ת/·ÖÖÓ
Speed
300 Rpm
¹¤×÷ζÈ
-40 ¡æ ~ +80 ¡æ
Operation temp.
-40 ¡æ ~ +80 ¡æ
Ť¾Ø
0.01N.M
Torque
0.01N.M
·À»¤µÈ¼¶
IP54
Seal class
IP54
»ù±¾Ðͺż°³ß´ç Basic Model and Size
»ù±¾ÐͺÅ
Model NO.
ͨ·Êý
Circuits
³¤¶ÈL
Length “L”
PSR-C6
6
14.5mm
PSR-C12
12
21.3mm
PSR-C15
15
29.5mm
PSR-C18
18
35.1mm
PSR-C24
24
35.1mm
¹«Ë¾Ãû³Æ£º ÉîÛÚÊб¼Áª»úµç¼¼ÊõÓÐÏÞ¹«Ë¾
µç »°£º 0755 29702762 / ÀÁÖ
ÊÖ»ú£º 15989425328
µØ Ö·£º ÉîÛÚÊб¦°²Çøº½³Ç´óµÀ»ª·áÊÀ¼Í¿Æ¼¼Ô°B2¶°
ÓÊ ±à£º 518126
Ö÷ Ò³£º http://www.pan-link.cn
  • Ë®Òø»¬»·
  • µ¼µç»¬»·
  • ñʽµ¼µç»¬»·
  • ¹âÏË»¬»·
  • ·çµç»¬»·
  • µ¼µç»¬»·
  • »¬»·¹âÏË»¬»·
  • ¹âÏË»¬»·
  • Î÷ÃÅ×ÓϵͳרÓû¬»·
  • ¸ßÇåµ¼µç»¬»·/¸ßƵµ¼µç»¬»·
