΢ÐÍñʽµ¼µç»¬»·ÊÇ¿ÇÌ帽ÓÐÔ²Ðη¨À¼µÄһϵÁе¼µç»¬»·µÄͳ³Æ£¬Ö÷ÒªÓÃÓÚ´«Ê侫ÃÜÐźţ¬Î¢ÈõµçÁ÷£»¾ßÓеÍŤ¾Ø£¬µÍËðºÄÃâά»¤£»µÍµçÆøÔëÒôµÈÖ÷ÒªÌØµã£»
PSR-MsÊÇ΢Ð͵ÄñʽϵÁвúÆ·£¬½Ó´¥²ÄÁÏʹÓý𡣲ÊÉ«Ä͸ßε¼Ïß¼ò»¯µçÆøÁ¬½Ó¡£
PSR-MsµÄÉè¼ÆÓëPSR-CsÏàÀàËÆ£¬µ«Ìå»ý¸üС£¬¸üÄÜÂú×ã¿Á¿ÌµØ¿Õ¼äµÄϵͳÐèÇó£»
PSR-Ms°üº¬PSR-M6£¬PSR-M8£¬PSR-M12Èý¿îµ¼µç»¬»·»ù±¾Ðͺţ¬Ìṩ6·£¬8·£¬12·´«Êäµç·£»²¢Óжà¿îÍâÐÍÑùʽ¿É¹²Ñ¡Ôñ£¬»ò¿É¸ù¾Ý¿Í»§ÐèÇó¶¨ÖÆÍâÐÍ£»
The PSR-Ms slip ring miniature capsule is a standard,
off-the-shelf series product, that uses gold contacts at
the rotary interface. Color-coded lead wires are used
on both the stator and rotor for simplified electrical connections..
Using a 90o V-groove ring design for each ring, the PSR-Ms provides smoother running, lower torque low contact wear rates than competitive slip ring. PSR-Ms include PSR-M6, PSR-M8, PSR-M12 slip ring model, provides 6, 8, 12 circuit configurations.
