²úÆ·Ãû³Æ£º
MARSH¿ØÖƲâÊÔ¾«ÃÜѹÁ¦±í
ÐÍ ºÅ£º
DϵÁпØÖƲâÊÔ¾«ÃÜѹÁ¦±í
¾«¶ÈAccuracy |
ASME Grade 3A ¨C ¡À0.25% of range across full scale |
±í¾¶Case Sizes |
6" (160mm) diameter |
Íâ¿Ç²ÄÖÊCase Material |
304 Stainless Steel |
°²×°·½Ê½Case Style |
LM¨CLower Mount |
ÄÚо²ÄÖÊTube & Socket |
Copper alloy |
Ô˶¯¼þ²ÄÖÊMovement |
Stainless Steel |
½Ó¿ÚConnection |
1/4 NPT through 600 psi 1/2 NPT 1000 psi & above |
²âÁ¿·¶Î§Ranges |
0 to 30" Hg VAC; Compound 30" Hg to 60 psi; 15 to 10,000 psi |
¿Ì¶ÈÅÌDial Standard |
single scale psi |
¿Ì¶ÈÅÌÑÕÉ«Dial Color |
Black markings on white aluminum with mirror dial to avoid parallax |
Ö¸ÕëPointer |
Knife-edge Aluminum, black painted |
´°¿ÚWindow |
Instrument Glass |
ѹÁ¦ÊÍ·ÅPressure Relief |
Blowout plug |
MARSH¿ØÖƲâÊÔ¾«ÃÜѹÁ¦±í¶©»õÑ¡ÐÍPart Numbers: |
³ß´ç |
6" (160mm) |
Á¬½Ó |
1/4 NPT |
1/2 NPT |
0 to 30" Hg VAC |
D31405 |
30" Hg VAC to 15 psi |
D31410 |
30" Hg VAC to 30 psi |
D31412 |
30" Hg VAC to 60 psi |
D31414 |
0 to 15 psi |
D31440 |
0 to 30 psi |
D31442 |
0 to 60 psi |
D31446 |
0 to 100 psi |
D31448 |
0 to 160 psi |
D31452 |
0 to 200 psi |
D31454 |
0 to 300 psi |
D31458 |
0 to 400 psi |
D31460 |
0 to 600 psi |
D31464 |
0 to 1,000 psi |
D31472 |
0 to 1,500 psi |
D31474 |
0 to 2,000 psi |
D31476 |
0 to 3,000 psi |
D31478 |
0 to 5,000 psi |
D31482 |
0 to 10,000 psi |
D31490 |
