| 产品名称: |
充油耐震纯铜压力表
| 型 号: |
Marsh63mm 100mm |
| 价 格: |
0.00 |
| 品 牌: |
产品介绍: |
63mm 100mm 充油耐震纯铜压力表
精度Accuracy |
63mm: ±1.6% of range across full scale 100mm: ASME Grade 1A - ±1% of range across full scale |
表径Case Size |
63mm diameter (2.5") 100mm: diameter (4.0") |
外壳材质Case Material |
Forged Brass |
安装方式Case Style |
LM – Lower Mount |
内芯材质Tube & Socket |
Copper alloy |
运动件材质Movement |
Brass |
接口Connection |
63mm: 18260;4" NPT 100mm: 18260;2" NPT |
测量范围Ranges |
0-30" Hg vacuum; compound ranges 30" Hg vacuum to 200 psi; and 15-10,000 psi |
刻度盘Dial Standard |
Single Scale psi |
刻度盘颜色Dial Color |
Black markings on white |
指针Pointer |
Aluminum, black painted |
窗口Window |
Acrylic |
限位器Restrictor |
63mm: Gold Plated ABS 100mm: Steel, Chrome Plated |
充液材质Fill Medium |
Glycerine Standard |
排气塞Vent Plug |
Rubber plug with snip-off feature |
MARSH 63mm 100mm 充油耐震纯铜压力表订货选型Part Numbers: |
Type: |
63mm Brass |
100mm Brass |
Size |
63mm |
100mm |
Case Material |
Forged Brass |
Forged Brass |
Internals |
Copper Alloy |
Copper Alloy |
Mounting / Case Style |
LM |
LM |
Connection |
1/4" NPT |
1/2" NPT |
Scale Standard |
psi |
psi |
0 to 30" Hg VAC |
W9005PE |
W9405PE |
30" Hg VAC to 30 psi |
W9012PE |
W9412PE |
30" Hg VAC to 60 psi |
W9014PE |
W9414PE |
30" Hg VAC to 100 psi |
W9016PE |
W9416PE |
30" Hg VAC to 200 psi |
W9020PE |
W9420PE |
0 to 15 psi |
W9040PE |
W9440PE |
0 to 30 psi |
W9042PE |
W9442PE |
0 to 60 psi |
W9046PE |
W9446PE |
0 to 100 psi |
W9048PE |
W9448PE |
0 to 160 psi |
W9052PE |
W9452PE |
0 to 200 psi |
W9054PE |
W9454PE |
0 to 300 psi |
W9058PE |
W9458PE |
0 to 400 psi |
W9060PE |
W9460PE |
0 to 600 psi |
W9064PE |
W9464PE |
0 to 1,000 psi |
W9072PE |
W9472PE |
0 to 1,500 psi |
W9074PE |
W9474PE |
0 to 2,000 psi |
W9076PE |
W9476PE |
0 to 3,000 psi |
W9078PE |
W9478PE |
0 to 5,000 psi |
W9082PE |
W9482PE |
0 to 6,000 psi |
W9084PE |
W9484PE |
0 to 7,500 psi |
W9086PE |
W9486PE |
0 to 10,000 psi |
W9090PE |
W9490PE |
| 关 键 词: |
Marsh压力表 充油耐震压力表 纯铜压力表 |
公司名称:
北京杰德莱特科技有限公司
| 联 系 人: |
王强
| 电 话: |
010-85501516
| 手 机: |
15601046548 |
| 地 址: |
北京市朝阳区朝阳路67号财满街8号楼01110室 |
| 邮 编: |
100025 |
| 主 页: |
