产品名称: MARSH 100mm充油耐震压力表
型  号: MARSH X系列充油耐震压力表
MARSH 100mm充油耐震压力表
精度Accuracy
ASME Grade A – ±2/1/2% (±1% of range across middle half of scale)
表径Case Size
100mm (3.89") diameter
外壳材质Case Material
304 Stainless Steel
安装方式Case Style
Rolled ring, hermetically sealed case
CB – Center Back Mount
LM – Lower Mount
UC– U-Clamp Mount
内芯材质Tube & Socket
Copper alloy or 316 stainless steel
运动件材质Movement
Brass
接口Connection
1/4" NPT
测量范围Ranges
0 to 30" Hg VAC
Compound 30" Hg VAC to 300 psi
15 to 10,000 psi
刻度盘Dial Standard
Dual scale psi & kPa
刻度盘颜色Dial Color
Black markings on white
指针Pointer
Aluminum, Black painted
窗口Window
Polycarbonate
限位器Restrictor
Glycerine - Standard
充液材质Fill Medium
Standard for all ranges
排气塞Vent Plug
Removable tip for venting
MARSH 100mm充油耐震压力表选型Part Numbers:
Type: 100mm Severe Service Gauge
Internals
Copper Alloy
Stainless Steel
Mounting / Case Style
LM
CB
UC
LM
CB
UC
0 to 30" Hg VAC
X32965P
X32967P
30" Hg VAC to 30 psi
X32501P
30" Hg VAC to 60 psi
X32502P
30" Hg VAC to 100 psi
30" Hg VAC to 150 psi
X32887P
X32901P
X32894P
X32929P
X32941P
X32935P
30" Hg VAC to 200 psi
X32888P
X32902P
X32895P
X32930P
X32942P
X32936P
X32889P
X32903P
X32896P
X32931P
X32943P
X32937P
0 to 15 psi
X32504P
X32546P
X32525P
X32630P
X32678P
X32654P
0 to 30 psi
X32505P
X32547P
X32526P
X32631P
X32679P
X32655P
0 to 60 psi
X32506P
X32548P
X32527P
X32632P
X32680P
X32656P
0 to 100 psi
X32507P
X32549P
X32528P
X32633P
X32681P
X32657P
0 to 160 psi
X32508P
X32550P
X32529P
X32634P
X32682P
X32658P
0 to 200 psi
X32509P
X32551P
X32530P
X32635P
X32683P
X32659P
0 to 300 psi
X32510P
X32552P
X32531P
X32636P
X32684P
X32660P
0 to 400 psi
X32511P
X32553P
X32532P
X32637P
X32685P
X32661P
0 to 600 psi
X32512P
X32554P
X32533P
X32638P
X32686P
X32662P
0 to 1,000 psi
X32513P
X32555P
X32534P
X32639P
X32687P
X32663P
0 to 1,500 psi
X32514P
X32556P
X32535P
0 to 2,000 psi
X32515P
X32557P
X32536P
X32641P
X32689P
X32665P
0 to 3,000 psi
X32516P
X32558P
X32537P
X32642P
X32690P
X32666P
0 to 5,000 psi
X32518P
X32560P
X32539P
X32644P
X32692P
X32668P
0 to 6,000 psi
X32519P
X32561P
X32540P
X32645P
X32693P
X32669P
0 to 10,000 psi
X32647P
X32695P
X32671P
NOTE: shaded areas indicate items are available on special order, however, minimums and lead times apply. Consult factory.
关 键 词: MARSH压力表 X系列压力表 充油耐震压力表
公司名称: 北京杰德莱特科技有限公司
联 系 人: 王强
电  话: 010-85501516
手  机: 15601046548
地  址: 北京市朝阳区朝阳路67号财满街8号楼01110室
邮  编: 100025
TESCOM高压调压阀-(44-42系列)
TESCOM液压调压阀-(54-28系列)
TESCOM装备气室调压(26-12系列)
TESCOM背压调压阀-(26-25系列)
TESCOM背压调压阀4(44-23系列)
TESCOM高压调压阀-(BB-1系列)
TESCOM高压调压阀-(44-13系列)
TESCOM低压调压阀-(26-16系列)
美国 BLUE WHIT(蹼轮式流量计 F-2000系列)
TESCOM高压调压阀-(44-11系列)
TESCOM高压调压阀-(44-18系列)
微型流量比例阀(EVP-10-0925)
ASCO 板接式电磁阀 (SCG551A001ms)
美国 BLUE WHIT(蹼轮式流量计 F-1000系列)
GLE系列超微型电磁阀(GLE系列)
GLD-Cryo系列高压(GLD-Cryo系列)
GLM系列超微型电磁阀(GLM系列)
GL110,120系列电(GL110,120系列)
BELLOFRAM T1(T1000 电气转换器)
Valtek Beta
