FPM-3150
Industrial Flat Panel Monitor with 15" LCD
in Direct-VGA Port
Ö÷ÒªÌØµã£º
15" XGA TFT LCD with resolution up to 1024 X 768
High luminance up to 350 cd/m2
Supports Rack, Panel, Wall mount, VESA ARMS, Desktop Stand
Stainless steel chassis with NEMA4/IP65-compliant aluminum front panel
Auto-recognition of input signal
²úÆ·½éÉÜ
The FPM-3150 is an 15-inch color TFT LCD flat panel monitor specifically designed for industrial applications. With a viewing size as large as 15", it presents an ample display area as well as vivid and sharp images for your HMI. The FPM-3150 features Direct-VGA signal transmission, which allows a regular VGA control card to be used on your system. Users can thus upgrade the display without making changes to the existing system. Its On Screen Display function also allows users to adjust the images on screen with ease. The whole chassis is stainless steel and the front panel is made of aluminum with NEMA4/IP65 compliance.
