²úÆ·Ãû³Æ£º
ãü¸ñWP-8147×Ô¶¯»¯¼ÆËã»ú
ÐÍ ºÅ£º
WP-8147
| ²úÆ·Ãû³Æ: |
WP-8147 |
| ²úÆ·½éÉÜ: |
Ö§³ÖISaGRAF±à³ÌµÄWP-8141¡£ |
| ²úÆ·ÌØµã: |
Èí¼þÌØÐÔ£º¿ª·¢Èí¼þ: ISaGRAF Ver.3 ISaGRAFµÚÈý°æ±¾ ÔËÐÐÓÚWindows 95/ 98/ NT/ 2000/ XP ¶ÀÁ¢Éè¼Æ»·¾³ Ö§³Ö6ÖÖPLCÓï·¨(IEC 61131-3 5ÖÖ±ê×¼ÓïÑÔ + 1ÖÖÁ÷³Ìͼ) Ö§³Ö×î´ó1 Mbytes ISaGRAF´úÂë´óС Ö§³ÖÀëÏß·ÂÕæ ÔÚÏßµ÷ÊÔ,¼àÊÓÓë¿ØÖÆ ÇáËɼ¯³Éµ½HMI / SCADA / MMI Windows CE.Net 5.0 Ö§³ÖModbus Master RTU, ASCII, RS-232/485/422 Ö§³ÖModbus RTU/TCP Slave Modbus RTU (RS-232/485/422) Slave Modbus TCP/IP Slave (×î´ó32¸öÁ¬½Ó) Ö§³ÖÊý¾Ý½»»» Ebus: ͨ¹ýÒÔÌ«Íø PAC µ½ PAC Ö§³Ö CAN / CANopen (ͨ¹ý I-7530»òI-8120W) Ö§³ÖFRnet I/O Ö§³ÖÔ˶¯¿ØÖÆ Ö§³Ö·¢ËÍ´øÓÐÒ»¸öÎļþµÄE-MAIL Ö§³ÖSMS: ¶ÌÏûÏ¢·þÎñ GSM modem Ö§³ÖÎÞÏßͨÐÅ ÎÞÏ߹㲥 Ö§³ÖÊý¾Ý¼Ç¼ºÍÊý¾Ý×Ô¶¯²â¶¨ Ö§³Ö×Ô¶¯±¨¸æ²É¼¯/¿ØÖÆÊý¾Ý
Ó²¼þÌØÐÔ£ºÇ¿¾¢CPUÄ£¿é PXA270 CPU: 32-bit & R520 MHz»ò¼æÈÝµÄ 128 Mbytes SRAM 14 MbytesÄÚÖÃFlash´æ´¢Æ÷ ÄÚÖÃVGA ¶Ë¿Ú 64λӲ¼þÐòÁкŠ±£»¤Èí¼þºÍÓ¦ÓóÌÐò ·á¸»I/OÀ©Õ¹ÄÜÁ¦ RS-232/485/422 Ethernet FRnet CAN I/OÈȲå°Î¹¦ÄÜ I-87K¸ß¿¨¼´²å¼´Óà ÄÚÖÃFlash´æ´¢Æ÷ (14 MB) Á¼ºÃÊÊÓ¦Õ𶯻·¾³,£¬ÀýÈ磺º£ÔË Ë«¿´ÃŹ·¶¨Ê±Æ÷Ôö¼Ó¿É¿¿ÐÔ Ë«ºó±¸µç³ØSRAM (512Kbytes) µôµç¿Éά³ÖÊý¾Ý5Äê Ë«ÒÔÌ«Íø¿Ú ÈßÓàÒÔÌ«ÍøÍ¨ÐÅ È«ÇòInternet /˽ÓÐÒÔÌ«Íø·Öɢϵͳ ÈßÓàµçÔ´Ö§³Ö ·ÀֹϵͳµôµçʧЧ ͨ·çÉè¼ÆÔÊÐíÔËÐÐζÈ-25¡ãC ~ +75¡ãC |
| ²úÆ·²ÎÊý: |
Èí¼þ ²Ù×÷ϵͳ£ºWindows CE.Net 5.0 Compact Framework 2.0 Ö§³ÖFTP, Web£¨VB, JAVA) , SQL server ¿ª·¢Èí¼þ:ISaGRAF Software ISaGRAFµÚÈý°æ : IEC 61131-3±ê×¼ÓïÑÔ: LD, ST, FBD, SFC, IL & FC ×î´ó´úÂë´óС:WP-8x47ÔÊÐí×î´ó 1 Mbytes ISaGRAF´úÂë´óС(Appli.x8m±ØÐë< 1M) Web·þÎñ:Web HMI Ö§³ÖWeb HMIº¯Êý, PC¿ÉÒÔÔËÐÐIEä¯ÀÀÆ÷·ÃÎÊWP-8x47¾Óɱ¾µØÒÔÌ«Íø,Internet»òÕß²¦ºÅè¼àÊӺͿØÖÆ. °²È«Web HMIÖ§³Ö3²ãÓû§ÃûºÍÃÜÂë±£»¤
Ó²¼þ ´¦ÀíÆ÷£ºPXA270 »ò¼æÈÝ £¨32-bit and 520MHz£© SDRAM£º128MB Ë«µç³Ø±¸·ÝSRAM£º512K bytes £¨5ÄêÊý¾Ý±£´æ£© Flash£º48 MB £¨32 MB²Ù×÷ϵͳ, 15 MBÄÚÖÃÄÚ´æ´ÅÅÌ, 1 MB×¢²á±í£© EEPROM£º16K bytes£¬£¨Êý¾Ý±£´æ£º 40Äꣻ ¿É²Áд1000000´Î¡££© À©Õ¹ÉÁ´æ£º1GBµÄSD¿¨ ĬÈϹ¦ÄÜ£º64λӲ¼þΨһÐòÁкŠ¸´Î»°´Å¥ LEDָʾµÆ NET ID 1 ~ 255, Èí¼þÉèÖà ¿´ÃŹ· ʵʱʱÖÓ Ðýת¿ª¹Ø DIP¿ª¹Ø£ºÎÞ Í¨Ñ¶½Ó¿Ú VGA¡Á1 (800¡Á600) ÒÔÌ«Íø¿Ú£¨10/100 BaseT£©¡Á 2 USB 1.1¡Á1 COM 1£ºRS-232 (³ÌÐòÏÂÔØ¿Ú) (RXD, TXD, GND) COM 2£ºRS-485 (D2+, D2-); 3000VDC ¸ôÀë I/OÀ©Õ¹²å²Û£º1£¨½öÖ§³ÖI-8000ºÍI-87K¸ß¿¨Ä£¿é£© ³ß´ç£º 95mm x 132 mm x 98 mm ²Ù×÷»·¾³ ¹¤×÷ζȣº-25 ¡æ ~ +75 ¡æ Öü´æÎ¶ȣº-30 ¡æ ~ +85 ¡æ Ïà¶Ôʪ¶È£º5 ~ 90%, ÎÞÀäÄý µçÔ´ µçÔ´µçѹ£º+10V ~ +30V µçÔ´¸ôÀ룺1KV ÈßÓàµçÔ´Ö§³Ö£ºYes µçÔ´ÈÝÁ¿£ºCPUºÍ±³°å¹©µç:1A, 5V I/OÀ©Õ¹²Û¹©µç:0.6A,5V ×ÜÈÝÁ¿:8W ¹¦ºÄ£º 7.3W |
