产品名称: nikkidenso伺服马达NA100系列
型  号: NA100
价  格:
品  牌: 日机电装nikki denso
■AC servomotor NA100Series
日本NIKKIDENSO NA100系列伺服电机用于产业机械,作为产业机械通用伺服电机,其功率范围大(0.6KW-22KW),具有功率密度大,精度高,响应快等特点.
Item Unit Type NA100-20F NA100-40F NA100-75F NA100-110F NA100-180F NA100-270F
Rated output kW 0.6 0.8 1.5 2.2 3.7 5.5
Number of poles P 4 4 4 4 4 4
Rated torque Nm(kgfm) 1.86 (0.19) 3.82 (0.39) 7.15 (0.73) 10.49 (1.07) 17.74 (1.81) 26.36 (2.69)
Rated speed rpm 3000 2000 2000 2000 2000 2000
Rated current A 4.3 5.6 10.5 15 27 40
Instantaneous max. torque Nm(kgfm) 9.31 (0.95) 19.11 (1.95) 25.97 (2.65) 52.43 (5.35) 88.89 (9.07) 132.00 (13.47)
Excitation current A 1.9 2.6 6.5 7.8 15 19
Power rate kW/s 8.6 17.7 34.1 62.7 73.2 98.5
Angular accel rad/s2 4634 4643 4771 5978 4147 3754
Rotor inertia kgfms2 0.000041 0.000084 0.000153 0.000179 0.000434 0.000714
Rotor GD2 kgfm2 0.0016 0.0033 0.0060 0.007 0.017 0.028
Cooling method --- Full closed natural cooling Full closed natural cooling Full closed natural cooling Full closed forced cooling Full closed forced cooling Full closed forced cooling
Weight Standard motor kg 6 12 18 20 31 37
Motor with brake kg 12 16 22.5 25 39 46
Applicable controller NCS-FI**M
NPS-FIM
801 801 122 242 402/752 752/113
Item Unit Type NA100-370F NA100-550F NA100-750F NA100-1100F
Rated output kW 7.5 11 15 22
Rated torque Nm(kgfm) 35.97 (3.67) 52.92 (5.40) 72.03 (7.35) 105.64 (10.78)
Rated speed rpm 2000 2000 2000 2000
Rated current A 54 76 103 146
Instantaneous max. torque Nm(kgfm) 180.12 (18.38) 264.60 (27.00) 360.15 (36.75) 528.22 (53.90)
Excitation current A 27 37 55 75
Power rate kW/s 135 184 186 279
Angular accel rad/s2 3767 3503 2598 2658
Rotor inertia kgfms2 0.000969 0.00153 0.00281 0.00403
Rotor GD2 kgfm2 0.038 0.06 0.11 0.158
Cooling method --- Full closed forced cooling Full closed forced cooling Full closed forced cooling Full closed forced cooling
Weight Standard motor kg 47 80 100 140
Motor with brake kg 56 92 110 170
NPS-FIM
153 153 223 303
Specification of 2000 rpm type AC400V/440V (50/ 60Hz) power input
Rated values
-550F-20H
NA100
-750F-20H
NA100
-1100F-20H
Rated output kW 11 15 22
Rated torque Nm(kgfm) 52.52 (5.36) 71.54 (7.30) 104.95 (10.71)
Rated current A 34 46 65
Instantaneous max. torque Nm(kgfm) 264.6 (27.0) 360.15 (36.75) 528.22 (53.9)
Excitation current A 13.5 24 33
Power rate kW/s 184 186 279
Angular accel rad/s2 3503 2598 2658
Rotor inertia kgfms2 0.00153 0.00281 0.00403
Rotor GD2 kgfm2 0.06 0.11 0.158
Weight Standard motor kg 80 100 160
Motor with brake kg 92 110 170
NPS-FIM
113 153/223 223/303
NA100-20F/NA100-40F/NA100-75F/NA100-110F/NA100-180F/NA100-270F/NA100-370F/NA100-550F/NA100-750F/NA100-1100F
NA100-20FB/NA100-40FB/NA100-75FB/NA100-110FB/NA100-180FB/NA100-270FB/NA100-370FB/NA100-550FB/NA100-750FB/NA100-1100FB
NA100-75F-10/NA100-110F-10/NA100-180F-10/NA100-270F-10/NA100-370F-10/NA100-550F-10/NA100-750F-10/NA100-1100F-10
NA100-75FB-10/NA100-110FB-10/NA100-180FB-10/NA100-270FB-10/NA100-370FB-10/NA100-550FB-10/NA100-750FB-10/NA100-1100FB-10
NA100-550F-20H/NA100-750F-20H/NA100-1100F-20H
NA100-550FB-20H/NA100-750FB-20H/NA100-1100FB-20H
关 键 词: NA100-370F NA100-180F NA100-110
公司名称: 上海奥茵绅机电科技有限公司
联 系 人: 耿新红
电  话: 086-18964531017
手  机: 13916694162
地  址: 上海市浦东新区金桥出口加工区金豫路100号1号楼1005室
邮  编: 201206
日机电装(ND)
SynqNet伺服驱动器(CSDH)
闭环步进电机(STEBRO-S)
UVW工作台(NAF3C-16)
中空轴电机(中控制电机)
DD马达(ND110-65F)
中空轴电机(中空轴电机)
NIKKIDENSO (NPS)
NIKKIDENSO (NCS)
NIKKIDENSO (NPSA)
NA70伺服马达(NA70)
NPS-FIMB系列驱动(NPS-FIMB-401)
NA50系列伺服马达(NA50)
NA20系列伺服马达(NA20-1800H)
NA30系列马达(NA30)
NPS驱动器(NPS-FIMA-242)
真空电机平台
高精度转台(ND)
YOKOGAWA DD马(DM,DR,DB)
