| NIKKIDENSOËÅ·þÂí´ïNA30ϵÁÐ |
NA30ϵÁÐËÅ·þÂí´ïΪ±âƽÐÍÂí´ï£¬ÊÊÓÃÓÚ¿Õ¼äÉè¼Æ£¬¶àÓÃÓÚÍä¹Ü»ú£¬×ªÌ¨µÈÉ豸£¬¹¦ÂÊ·¶Î§´Ó0.2KW-2.8Kw£¬²ÉÓÃÈ«·â±Õ×ÔÀ䷽ʽ£¬Âí´ï·¨À¼³ß´ç·¶Î§´Ó130mm-225mm£¬ºñ¶È·¶Î§´Ó159mm-203mm,Êʺϰ²×°¿Õ¼ä½Ï¶ÌÇÒ¹¦Âʽϴ󳡺ÏʹÓÃ. |
| ¡öAC servomotor NA30Series |
Item |
Unit Type |
NA30
-13F-15 |
NA30
-25F-15 |
NA30
-50F-15 |
NA30
-110F-15 |
NA30
-180F-15 |
Rated output |
kW |
0.2 |
0.4 |
0.8 |
1.6 |
2.8 |
Rated torque |
Nm |
1.27 |
2.55 |
5.10 |
10.19 |
17.84 |
Rated speed |
rpm |
1500 |
1500 |
1500 |
1500 |
1500 |
Rated current |
A |
1.7 |
3.4 |
6.4 |
13 |
22 |
max. torque |
Nm |
6.37 |
12.74 |
25.48 |
50.96 |
89.18 |
Power rate |
kW/s |
16.99 |
23.10 |
16.99 |
23.10 |
38.57 |
Rotor inertia |
kgfms2 |
0.000026 |
0.000064 |
0.000156 |
0.000459 |
0.000842 |
Weight |
Standard motor |
kg |
3.7 |
6.0 |
11.0 |
18.0 |
27.0 |
Driver |
NPS-FIM |
401 |
401 |
801 |
242 |
402 |
NCS-FI*M |
401 |
401 |
801 |
242 |
402 |
NA30-13F-15,NA30-25F-15,NA30-50F-15,NA30-110F-15,NA30-180F-15
