产品名称: NA20系列伺服马达
型  号: NA20-1800H
品  牌: 日机电装nikki denso
NIKKIDENSO伺服马达NA20系列
日机电装NIKKIDENSO提供大功率的伺服电机,功率范围15KW-220KW,AC交流伺服电机可带制动器和齿轮箱,用于大型产业设备,例如:大型转床,车床,切割设备,雕刻设备,印刷设备,注塑设备等场合,为客户提供性能优越的大功率伺服马达。型号:NA20-1500-10H,NA20-2200-10H,NA20-2700-10H,NA20-3700-10H,NA20-5500-10H,NA20-7500-10H,NA20-11000-10H,NA20-1500-20H,NA20-2200-20H,NA20-2700-20H,NA20-3700-20H,NA20-5500-20H,NA20-1500,NA20-1800,NA20-1500-10,NA20-2200-10,NA20-2700-10,NA20-3700-10
■AC servomotor NA20Series
Specification of 2000rpm type AC400/ 440V power input Rated values
Item Unit/ Type NA20
-1500-20H
NA20
-1800-20H
NA20
-2700-20H
NA20
-3700-20H
NA20
-5500-20H
Rated output kW 30 37 55 75 110
Number of poles P 4 4 4 6 6
Rated torque N・m(kgf・m) 144.1 (14.7) 177.4 (18.1) 288.1 (29.4) 355.7 (36.3) 524.3 (53.5)
Rated speed rpm 2000 2000 2000 2000 2000
Rated current A 89 108 164 252 340
Instantaneous max. torque N・m(kgf・m) 720.3 (73.50) 1078 (110.0) 1440.6 (147.00) 1776.7 (181.3) 2641.1 (269.5)
Excitation current A 31 32 50 80 160
Power rate kW/s 519 662 818 1036 1112.5
Angular accel rad/s2 3603 3732 3103 2900 2115
Rotor inertia kgf・ms2 0.00408 0.00485 0.00867 0.0158 0.0253
Rotor GD2 kgf・m2 0.16 0.19 0.34 0.62 0.99
Cooling method --- Drip proof forced air cooling Drip proof forced air cooling Drip proof forced air cooling Drip proof forced air cooling Drip proof forced air cooling
Weight kg 165 185 225 245 370
Applicable controller NPS-FIM 303 373 553 753 114
NCS-FI*M 303 373 △ △ △
1: As for the applicable controller with △mark, please ask our sales man.
2: Since values can be changed, please confirm when you use them for machine designing
Specification of 2000rpm/1000rpm type AC200/ 220V power input Rated values
-1500
NA20
-1800
NA20
-1500-10
NA20
-2200-10
NA20
-2700-10
NA20
-3700-10
Rated output kW 30 37 15 22 30 37
Number of poles P 4 4 4 4 4 6
Rated torque N・m(kgf・m) 144.1 (14.7) 177.4 (18.1) 144.1 (14.7) 211.3 (21.56) 288.1 (29.4) 355.7 (36.3)
Rated speed rpm 2000 2000 1000 1000 1000 1000
Rated current A 160 195 87 122 164 230
Instantaneous max. torque N・m(kgf・m) 720.3 (73.50) 1078 (110.0) 720.3 (73.50) 1056.4 (107.87) 1440.6 (147.00) 1776.7 (181.3)
Excitation current A 55 58 28 36 50 110
Power rate kW/s 519 662 513 766 964 803.9
Angular accel rad/s2 3603 3732 3581 3649 3369 2295
Rotor inertia kgf・ms2 0.00408 0.00485 0.00408 0.00587 0.00867 0.0058
Rotor GD2 kgf・m2 0.16 0.19 0.16 0.23 0.34 0.62
Cooling method --- Drip proof forced air cooling Drip proof forced air cooling Drip proof forced air cooling Drip proof forced air cooling Drip proof forced air cooling Drip proof forced air cooling
Weight kg 165 185 165 220 225 245
Applicable controller NPS-FIM 303 373 153 223 303 373
NCS-FI*M 303 373 153 223 303 373
Note: Since values can be changed, please confirm our sales man when you use them for machine designing
关 键 词: NIKKIDENSO NA20 NA20-
公司名称: 上海奥茵绅机电科技有限公司
联 系 人: 耿新红
电  话: 086-18964531017
手  机: 13916694162
地  址: 上海市浦东新区金桥出口加工区金豫路100号1号楼1005室
邮  编: 201206
日机电装(ND)
SynqNet伺服驱动器(CSDH)
闭环步进电机(STEBRO-S)
UVW工作台(NAF3C-16)
中空轴电机(中控制电机)
DD马达(ND110-65F)
中空轴电机(中空轴电机)
NIKKIDENSO (NPS)
NIKKIDENSO (NCS)
NIKKIDENSO (NPSA)
nikkidenso伺服(NA100)
NA70伺服马达(NA70)
NPS-FIMB系列驱动(NPS-FIMB-401)
NA50系列伺服马达(NA50)
NA30系列马达(NA30)
NPS驱动器(NPS-FIMA-242)
真空电机平台
高精度转台(ND)
YOKOGAWA DD马(DM,DR,DB)
