Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú »ú´²¿ØÖÆÃæ°å½Ó¿Ú6FC5312
²úÆ·Ãû³Æ£º »ú´²¿ØÖÆÃæ°å½Ó¿Ú6FC5312
ÐÍ ºÅ£º 6FC5312-0DA01-0AA0
Æ· ÅÆ£º 1
ÏêϸÃèÊö
Order No.
6FC5312-0DA01-0AA0
Product name
Machine Control Panel analog, MCPA module
Inputs/outputs, high-speed
16
Voltage at inputs/outputs
24 V DC
Degree of protection to EN 60529 (IEC 60529)
  • Front
IP00
  • Rear
IP00
Condensation
Not permissible
Humidity rating in accordance with EN 60721-3-3
Class 3K5 condensation and icing excluded.  Low ambient temperature 0¡ãC
Relative humidity
  • Storage
5 ¡­ 95%
  • Transport
5 ¡­ 95%
  • Operation
5 ¡­ 95%
Ambient temperature
  • Storage
-20 ... +60 ¡ãC (-4 ... +140 ¡ãF)
  • Transport
  • Operation
0 ... +50 ¡ãC (+32 ... +122 ¡ãF)
Weight, approx.
0.2 kg (0.44 lb)
Dimensions
  • Width
205 mm (8.07 in)
  • Height
95 mm (3.74 in)
  • Depth
50 mm (1.97 in)
¹«Ë¾Ãû³Æ£º ÉϺ£ØÂΌ¤Òµ¿ØÖÆÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 021 60346029 / ³ÂºÆ
ÊÖ»ú£º 13482833481
µØ Ö·£º Ëɽ­ÇøÎijÇ·¼ÎºÌÉÌÎñÖÐÐÄ358Ū1407ÊÒ
ÓÊ ±à£º 261620
Ö÷ Ò³£º http://www.gkong.com/products/pro_content.asp?products_id=1352431
  • Î÷ÃÅ×ÓËÅ·þÇý¶¯
  • Î÷ÃÅ×Ó×ÜÏßµçÀÂPROFIBUS DP×ÜÏß
  • Î÷ÃÅ×Ó1PH/1FNÖ÷Öáµç»ú
  • ÊÖ³Öʽµ¥ÔªB-MPIÐÍ
  • Î÷ÃÅ×ÓËÅ·þÇý¶¯Æ÷
  • Î÷ÃÅ×ÓÐÂÆÁ
  • ´¥ÃþÆÁ10´ç6AV6648
  • Î÷ÃÅ×ÓËÅ·þµç»ú
  • Î÷ÃÅ×Ó½»Á÷µ÷ËÙÆ÷
  • Î÷ÃÅ×ÓDP×ÜÏß½ÓÍ·
