Product name |
MCP 802D sl machine control panel |
Input voltage |
5 V DC +20%/-15% |
Power consumption |
5 W |
Inputs/outputs |
Connector acc. to MIL-C-83-503/DIN 41-651 |
Degree of protection to EN 60529 (IEC 60529) |
IP54 |
IP00 |
Humdity rating in accordance with EN 60721-3-3 |
Class 3K5 condensation and icing excluded. Low air temperature 0 ¡ãC (32 ¡ãF). |
Ambient temperature |
-20 ... +60¡ãC (-4 .... +140¡ãF) |
0 ... +50¡ãC (+32 ... +122¡ãF) |
Weight, approx. |
0.7 kg (1.54 lb) |
Dimensions |
170 mm (6.69 in) |
330 mm (12.99 in) |
60 mm (2.36 in) |
