产品名称: 欧陆EUROTHERM 多回路温度过程控制器900EPC
型  号: 900EPC
品  牌: 欧陆EUROTHERM
900EPC已经停止生产,现在用新型号2604/2704代替,咨询电话:020-32389052
The Eurotherm Model 900EPC Series of Controller/Programmers have moved to a Level 3 Obsolescence as of June, 2001. What does this mean?
  • Orders from existing or new customers are no longer accepted.
  • The 900EPC has been removed from any Product Catalogs and Price Lists.
  • Adequate spare parts and components will be stocked at the Leesburg, Virginia, Repair facility for continuing warranty and long term non-warranty support of the 900EPC Series.
  • The Eurotherm Repair facility will be able to provide service on the 900 EPC for a minimum of 3 years or more.
Is there a Replacement for the 900EPC? Yes!
There are two new products that are replacements for the 900 EPC. The model 2604 and 2704 three-loop controllers. The 2604 and the 2704 have the same cutout size as the 900EPC - 1/4 DIN. The 2604 has an LED display 2604 while the the 2704 has a graphical display. These instruments have a level of configurability, with math and logic functions and are supported by Eurotherm's new configuration software, iTools.
Actual Dimensions:
3.78H x 3.78W x 9.17D" (96H x 96W x 233Dmm)
(with rear terminal cover)
Panel depth (with rear terminal cover): 8.58" (218mm)
The 900EPC series of controllers and programmer/controllers are high stability, high accuracy, communicating units designed to cope with a wide range of process needs and environments. The 16-bit 68070 microprocessor delivers the power of a PC; a number of ASICs significantly increase the I/O capability.
The 900EPC controllers are available in both single and dual-loop versions, as well as cascade and ratio versions. They feature modular hardware and software for control of simple or complex loops. Applications include: temperature, flow, level, density, viscosity, humidity, carbon, melt pump, gravimetric feed systems and other processes.
 1:  1/4 DIN size
 2:  Many advanced features!
 3:  20 standard models for fixed control solutions
 4:  Accuracy=better than 0.1%
 5:  High speed input: up to 20 samples/sec.
 6:  PC communications + peer-to-peer
 7:  Optional 50 programs & 500 segments
 8:  Adjustable holdback available per program or per segment
 9:  6 hardware and software configurable I/O expansion slots
 10: Logic programming and software "user wiring" for custom applications
 11:  Real time clock for scheduled startup and shut down
 12:  Nema 4 (IP65) rating
理想适用于:
  • 气氛炉
  • 真空炉
  • 半导体炉
  • 蠕变和拉伸测试
  • 高压灭菌锅
  • 发酵罐和电抗器
  • 挤塑熔化压力
特性:
  • 3 个 PID 回路
  • 超高精度过程输入
  • 级联、比例、过调节
  • 设定点编程
  • 数学、逻辑和计时器
  • 氧化锆和真空输入
  • 熔化压力校准
  • 整装锅炉控制
关 键 词: 温度程控器 900EPC 欧陆温度程控器
公司名称: 广州博玮自动化设备有限公司
联 系 人: 曾莲莲
电  话: 020-32389052
手  机: 18002261356
地  址: 广州市黄埔区护林路104号骊丰大厦406室
邮  编: 510070
美国红狮Redlion模( CSPID)
美国红狮Redlion模(CSMSTRV2)
美国红狮Redlion模(CSTC8 / CSRTD6)
美国红狮Redlion模(CSSG)
美国红狮Redlion(CSINI8 / CSINV8)
美国红狮Redlion模(CSOUT)
美国Sixnet产品工业(通讯网关)
美国红狮Redlion模(CSMSTR LE/SX/GT)
美国Sixnet工业MO(VT-MODEM-5WW)
美国Sixnet产品工业(浪涌保护器)
美国Sixnet工业附件(工业电源)
美国Sixnet工业MO(VT-MODEM-4WW)
美国Sixnet产品工业(工业串口服务器)
美国Sixnet工业MO(VT-MODEM-3WW)
美国Sixnet工业MO(VT-MODEM-1WW)
美国红狮Redlion(G308K)
美国红狮Redlion (G306)
美国红狮Redlion(G306K)
美国红狮Redlion(G304K)
美国红狮Redlion(G315)
