欧陆EUROTHERM功率控制器TE10P
High precision control; accuracy and stability better than 1%
The TE10P provides accurate power control for a wide range of industrial, single phase loads. By using either an analogue or digital setpoint, the TE10P can be used for the precise control of power in loads that would otherwise prove difficult to accurately regulate.
Flexibility
The TE10P is configurable for different types of input, firing mode, feedback and load type. It is suitable for driving either simple resistive loads or complex loads such as Silicon Carbide, Platinum, Molybdenum or Short Wave Infrared lamps.
Dynamic load fault detection allows continuous monitoring of loads, including those with characteristics that are dependent on temperature or time.
The feedback type can be selected from; RMS Voltage, RMS Current, I2, V2, Transfer Between I2 and V2, transfer between I2 and Power, True Power or Open Loop.
Communications
Optional RS422 or RS485 communications with Modbus or Profibus protocol allow the TE10P to be configured or controlled from an external supervisory system.
Features
Current range from 16 to 400 amps, voltage range from 100 to 500 volts.
Four digit display and single push button, simplify Operating, Commissioning, Maintenance and Configuration.
Isolated Analogue retransmission of power.
Configurable Alarm Relay.
运用行业:
玻璃退火炉
金属炉
陶瓷炉
半导体生产
感应加热
变压器耦合负载
取决于时间/温度的负载
