Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¾µ·´Éäʽ¾àÀë´«¸ÐÆ÷ DMD
²úÆ·Ãû³Æ£º ¾µ·´Éäʽ¾àÀë´«¸ÐÆ÷ DMD
ÐÍ ºÅ£º DMD
¾µ·´Éäʽ
²âÁ¿·¶Î§£º0.5 ... 240Ã×
¾«È·¶È£º0,5 m ... 3,2 m ¡À 6ºÁÃ×
Êý¾Ý½çÃæ£ºProfibus, Interbus, SSI
Model Name Part Number Reproducibility Response time Accuracy Distance from ... to
DMD120-1111 6022175 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 120 m
DMD120-2111 6022181 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 120 m
DMD120-3111 6022178 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 120 m
DMD240-1111 6022176 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 240 m
DMD240-2111 6022182 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 240 m
DMD240-3111 6022179 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 240 m
DMD50-1111 6022174 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 50 m
DMD50-2111 6022180 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 50 m
DMD50-3111 6022177 0.2 mm at 50 ms meas. value period, 2 mm at 13 ms meas. value period 0.5 m ... 3.2 m +/- 6 mm > 3.2 m +/- 5 mm 0,5 ... 50 m
¹«Ë¾Ãû³Æ£º ¹ãÖÝÊÐÎ÷¿Ë´«¸ÐÆ÷ÓÐÏÞ¹«Ë¾
µç »°£º 020 28823600 / ¹ãÖÝÊÐÎ÷¿Ë´«¸ÐÆ÷ÓÐÏÞ¹«Ë¾
ÊÖ»ú£º
µØ Ö·£º ¹ãÖÝÊÐÌìºÓÇøÖé½­Î÷·15ºÅÖé½­³Ç´óÏÃ18Â¥
ÓÊ ±à£º 510623
Ö÷ Ò³£º www.sick.com
  • һάÂëÔĶÁÆ÷CLV602 ÉÏÊÐÀ²£¡
  • Î÷¿ËÐÂÆ·|VMS6200 ÐÐÀî¼°ÍÐÅ̼ì²âϵͳ
  • Î÷¿Ë °²È«Î»Öÿª¹Ø-I10-PA213/I10-RA213
  • Î÷¿Ë ͨµÀ·À»¤ÏµÍ³-Safe Entry Exit
  • Î÷¿Ë Visionary- S 3DÊÓ¾õ²ð¶âϵͳ
  • SICKÐÂÒ»´ú¸ßËÙ·ÖÌåʽ3DÏà»úRanger3
  • Î÷¿Ë CFP¡ª¡ª×î°Ù´îµÄҺλ´«¸ÐÆ÷
  • Î÷¿Ë¿áìÅ3D¿Æ¼¼¡ªTOF 3DÏà»ú
  • Î÷¿Ë ATM60¾ø¶ÔÖµÐͱàÂëÆ÷£ºÐÔÄܿɿ¿£¬Îȶ¨ÐÔÇ¿£¬Ä£¿é»¯Éè¼Æ
  • IMF ÎÀÉúÐͽӽü´«¸ÐÆ÷
