²úÆ·Ãû³Æ£º
LD-OEM1000Ô¶¾àÀëÈ«·½Î»ÐÍ ¼¤¹âɨÃèÆ÷
ÐÍ ºÅ£º
LD-OEM1000
ɨÃ跶Χ£¨×î´óÖµ/10%·´ÉäÂÊ£©£º250m/33m
ɨÃ跶Χ£º3600
½Ç¶È·Ö±æÂÊ£º0.125...10
·Ö±æÂÊ/ͳ¼ÆÎó²î£º3.9mm/typ.+/-25mm
LD-OEM1000¼¤¹âɨÃèÆ÷µÄÖ÷Òª¼¼Êõ²ÎÊý
LD-OEM1000 |
¼¤¹â¶þ¼«¹Ü²¨³¤: |
905nmºìÍâ¹â |
²âÁ¿¾àÀ루×î´óÖµ/10%·´ÉäÂÊ£© |
0...250m/34m |
·Ö±æÂÊ/ϵͳÎó²î/ͳ¼ÆÎó²î |
3.9mm/typ.¡À38mm/25mm |
ɨÃè½Ç¶È¼°½Ç¶È·Ö±æÂÊ |
360¡ã,0.125¡ã--1.0¡ã¿ÉÑ¡ |
ɨÃèÆµÂʼ°ÏìӦʱ¼ä |
5-15HZ£»53/26/13ms |
ͨѶÊý¾Ý½Ó¿Ú |
RS232 / RS422 / Ethernet / CAN / DSP |
ͨѶËÙÂÊ |
´®¿Ú4.8-115.2K£¬ 10MÒÔÌ«Íø |
¹¤×÷µçѹ/µçÁ÷ |
24VDC¡À15%£»×î´ó2.1A |
¿ª¹ØÁ¿Êä³ö |
4·PNP£»typ.24VDC |
¼¤¹â·À»¤µÈ¼¶ |
1¼¶£¨ÈËÑÛ°²È«£© |
·À»¤µÈ¼¶ |
IP 65, |
¹¤×÷ζÈ/´æ´¢ÎÂ¶È |
0¡ã- 45¡ã/-20--80¡ã |
ʪ¶È |
5-85%£¬ÎÞÄý¶ |
³ß´ç£¨W x H x D£©/ÖØÁ¿ |
115mm*222mm*120.5mm /2.4Kg |
