产品介绍: |
EMC电磁兼容
齐平式或非齐平式安装
PNP输出
感应距离可调校
常开/常闭输出功能
短路保护(脉冲式)
塑料外壳,带M30x1.5mm细螺纹
电缆或插头
防护等级IP67
LED状态指示灯
Model Name |
Part Number |
Switching output |
Connection type |
Installation in metal |
Max. sensing range |
CM30-16BNP-KC1 |
6021460 |
NPN |
Connector, M12, 4-pin |
Flush |
16 mm |
CM30-16BNP-KW1 |
6021459 |
NPN |
Cable, PVC, 2 m |
Flush |
16 mm |
CM30-16BPP-KC1 |
6020475 |
PNP |
Flush |
16 mm |
CM30-16BPP-KW1 |
6020473 |
PNP |
Cable, PVC, 2 m |
Flush |
16 mm |
CM30-25NNP-KC1 |
6021462 |
NPN |
Non-flush |
25 mm |
CM30-25NNP-KW1 |
6021461 |
NPN |
Cable, PVC, 2 m |
Non-flush |
25 mm |
CM30-25NPP-KC1 |
6020477 |
PNP |
Non-flush |
25 mm |
CM30-25NPP-KW1 |
6020476 |
PNP |
Cable, PVC, 2 m |
Non-flush |
25 mm |
CM30-16BAP-KW1 |
6028411 |
Cable, PVC, 2 m |
Flush |
16 mm |
CM30-25NAP-KW1 |
6028413 |
Cable, PVC, 2 m |
Non-flush |
25 mm | |
