产品介绍: |
- 可调校的高精度北京遮蔽功能
- 不受周围光源干扰(如HF高频光和闪烁的报警灯)
- 两传感器即使对面安装仍能可靠工作
- 工作温度为-40...600C
- 快速的响应时间
Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WTB4-3P1362 |
1028081 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3P2162 |
1028084 |
16 x 32 x 12 mm |
Connector, M8, 3-pin |
4 ... 150 mm |
WTB4-3P2262 |
1028085 |
16 x 32 x 12 mm |
Connector, M8, 4-pin |
4 ... 150 mm |
WTB4-3P2264 |
1028086 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3P3162 |
1028082 |
16 x 32 x 12 mm |
Cable with plug, M8, 3-pin, 100 mm |
4 ... 150 mm |
WTB4-3N1362 |
1028087 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3N1164 |
1028090 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3N2162 |
1028088 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3N3162 |
1028089 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3N1161 |
1028102 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3N1361 |
1028101 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3N2161 |
1028104 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3N3161 |
1028103 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3P1161 |
1028096 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3P1361 |
1028094 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3P2161 |
1028099 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3P2261 |
1028100 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3P3261 |
1028098 |
16 x 32 x 12 mm |
Cable with plug, M8, 4-pin, 100 mm |
4 ... 150 mm |
WTB4-3N1361 |
1028108 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3E2161 |
1028110 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3E3161 |
1028109 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3F1361 |
1028105 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3F2161 |
1028107 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3F3161 |
1028106 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTV4-3N1341 |
1028115 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 50 mm |
WTV4-3N2181 |
1028116 |
16 x 32 x 12 mm |
4 ... 50 mm |
WTV4-3P1341 |
1028111 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 50 mm |
WTV4-3P2181 |
1028113 |
16 x 32 x 12 mm |
4 ... 50 mm |
WTV4-3P2241 |
1028114 |
16 x 32 x 12 mm |
4 ... 50 mm |
WTB4-3P3161 |
1028097 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTV4-3P3441 |
1029582 |
16 x 32 x 12 mm |
Cable with plug, M12, 4-pin, 150 mm |
4 ... 50 mm |
WTB4-3N1371 |
1028125 |
16 x 32 x 12 mm |
Cable, 2 m |
4 ... 150 mm |
WTB4-3P2171 |
1028123 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4-3P3171 |
1028122 |
16 x 32 x 12 mm |
4 ... 150 mm |
WTB4T-3N1264 |
1028092 |
22 x 42 x 22 mm |
Cable, 5 m |
4 ... 120 mm |
WTB4T-3P1264 |
1028091 |
22 x 42 x 22 mm |
Cable, 5 m |
4 ... 120 mm |
WTV4-3P3141 |
1028112 |
16 x 32 x 12 mm |
Cable with plug, M8, 3-pin |
4 ... 50 mm | |
