产品介绍: |
- 2级红色激光光源
- 可调校的背景遮蔽功能
- 开关频率为1000/s
- 紧凑的ABS塑料外壳
Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WT9L-N330 |
1023991 |
12 x 40 x 22 mm |
Connector, M18, 4-pin |
30 ... 150 mm |
WT9L-N430 |
1023990 |
12 x 40 x 22 mm |
Connector, M12, 4-pin |
30 ... 150 mm |
WT9L-P330 |
1023977 |
12 x 40 x 22 mm |
Connector, M8, 4-pin |
30 ... 150 mm |
WT9L-P430 |
1023959 |
12 x 40 x 22 mm |
30 ... 150 mm |
WT9L-P330S02 |
1026600 |
12 x 40 x 22 mm |
30 ... 150 mm | |
