产品名称: 施克 镜反射式光电开关WL12-2
型  号: WL12-2
  • 红色光源
  • 可屏蔽周围环境光源
  • 可旋转900的M12插头或2m电缆
  • 灵敏度,可调较
    Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max
    WL12-2N120 1016084 15 x 49 x 41,5 mm Cable, 2 m 0 ... 2 m
    WL12-2N130 1016085 15 x 49 x 41,5 mm Cable, 2 m 0 ... 7 m
    WL12-2N420 1016091 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 2 m
    WL12-2N430 1016092 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 7 m
    WL12-2P120 1016095 15 x 49 x 41,5 mm Cable, 2 m 0 ... 2 m
    WL12-2P130 1016096 15 x 49 x 41,5 mm Cable, 2 m 0 ... 7 m
    WL12-2P420 1016101 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 2 m
    WL12-2P430 1016102 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 7 m
    WL12-2Z430 1016108 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 7 m
    WL12G-N530 1016309 15 x 49 x 41,5 mm Connector, M12, 5-pin 0 ... 3 m
    WL12G-P510 1016738 15 x 49 x 41,5 mm Connector, M12, 5-pin 0 ... 3 m
    WL12G-P530 1016289 15 x 49 x 41,5 mm Connector, M12, 5-pin 0 ... 3 m
    WL12G-V530 1016310 15 x 49 x 41,5 mm Connector, M12, 5-pin 0 ... 3 m
    WL12G-W530 1016311 15 x 49 x 41,5 mm Connector, M12, 5-pin 0 ... 3 m
    WL12-2B560 1016080 15 x 49 x 41,5 mm Connector, M12, 5-pin 0 ... 4 m
    WL12-2N730 1016088 15 x 49 x 41,5 mm Cable, 3 m 0 ... 7 m
    WL12-2P730 1016098 15 x 49 x 41,5 mm Cable, 3 m 0 ... 7 m
    WL12-2N180 1016089 15 x 49 x 41,5 mm Cable, 2 m 0 ... 7 m
    WL12-2N190 1016090 15 x 49 x 41,5 mm Cable, 2 m 0 ... 2 m
    WL12-2N480 1016093 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 7 m
    WL12-2N490 1016094 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 2 m
    WL12-2P180 1016099 15 x 49 x 41,5 mm Cable, 2 m 0 ... 7 m
    WL12-2P190 1016100 15 x 49 x 41,5 mm Cable, 2 m 0 ... 2 m
    WL12-2P480 1016106 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 7 m
    WL12-2P490 1016107 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 2 m
    WL12-2P460 1016105 15 x 49 x 41,5 mm Connector, M12, 4-pin 0 ... 4 m
  • Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max
    WL11-N130 1018681 15,2 x 51 x 43,5 mm Cable, 2 m 0 ... 7 m
    WL11-N430 1018682 15,2 x 51 x 43,5 mm Connector, M12, 4-pin 0 ... 7 m
    WL11-P130 1018680 15,2 x 51 x 43,5 mm Cable, 2 m 0 ... 7 m
    WL11-P430 1018510 15,2 x 51 x 43,5 mm Connector, M12, 4-pin 0 ... 7 m
    WL11-B560 1019704 15,2 x 51 x 43,5 mm Connector, M12, 5-pin 0 ... 4 m
    WL11-R130 1026232 15,2 x 51 x 47 mm Cable, 2 m 0,1 ... 7 m
关 键 词: 施克 镜反射式光电开关
公司名称: 广东西克智能科技有限公司
联 系 人: 广东西克智能科技有限公司
电  话: 020-28823600
手  机:
地  址: 广州市天河区珠江西路15号珠江城大厦18楼
邮  编: 510623
一维码阅读器CLV602
西克新品|VMS6200(VMS6200)
西克 安全位置开关-I1(I10-PA213)
西克 通道防护系统-Sa(Safe Entry Exit)
西克 Visionary
SICK新一代高速分体式(高速分体式3D相机Ranger3)
西克 CFP——最百搭的(CFP——最百搭的液位传感器)
西克酷炫3D科技—TOF(TOF 3D相机)
西克 ATM60绝对值型( ATM60)
IMF 卫生型接近传感器(IMF 卫生型)
G6 迷你型光电传感器(G6 迷你型)
W2S-2 迷你型光电传(W2S-2 迷你型)
IQ40 方形接近传感器(IQ40)
Lector63x 二维(Lector63x)
LMS141 紧凑型激光(LMS141)
DBV50 Core 测(DBV50 Core)
UD18 超声波传感器(UD18)
H18 SureSens(H18)
IO-Link Mast(IO-Link Master)
3Vistor-P CV(3Vistor-P CV)
