产品介绍: |
- 通过明亮光点实现快速安全的设置
- 更能有效预防误动作
- 容易在狭槽和导轨内安装
| Results |
Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WSE4-3N1330 |
1028164 |
16 x 32 x 12 mm |
Cable, 2 m |
0 ... 5,5 m |
WSE4-3N2130 |
1028167 |
16 x 32 x 12 mm |
Connector, M8, 3-pin |
0 ... 5,5 m |
WSE4-3P1330 |
1028159 |
16 x 32 x 12 mm |
Cable, 2 m |
0 ... 5,5 m |
WSE4-3P1330 |
1029645 |
16 x 32 x 12 mm |
Cable, 5 m |
0 ... 5,5 m |
WSE4-3P2130 |
1028163 |
16 x 32 x 12 mm |
0 ... 5,5 m |
WSE4-3P2230 |
1028160 |
16 x 32 x 12 mm |
Connector, M8, 4-pin |
0 ... 5,5 m |
WSE4-3P3130 |
1028161 |
16 x 32 x 12 mm |
Cable with plug, M8, 3-pin, 100 mm |
0 ... 5,5 m |
WSE4-3E1330 |
1028172 |
16 x 32 x 12 mm |
Cable, 2 m |
0 ... 5,5 m |
WSE4-3E2130 |
1028175 |
16 x 32 x 12 mm |
0 ... 5,5 m |
WSE4-3E3130 |
1028174 |
16 x 32 x 12 mm |
0 ... 5,5 m |
WSE4-3F1330 |
1028168 |
16 x 32 x 12 mm |
Cable, 2 m |
0 ... 5,5 m |
WSE4-3F2130 |
1028171 |
16 x 32 x 12 mm |
0 ... 5,5 m |
WSE4-3F3130 |
1028170 |
16 x 32 x 12 mm |
0 ... 5,5 m |
WSE4T-3E1430 |
1029648 |
22 x 42 x 22 mm |
Cable, 5 m |
0 ... 3 m |
WSE4T-3F1430 |
1029647 |
22 x 42 x 22 mm |
Cable, 5 m |
0 ... 3 m |
WSE4T-3P1430 |
1029646 |
22 x 42 x 22 mm |
Cable, 5 m |
0 ... 3 m | |
