宝盟FVDK 10N67Y0光纤放大器
瑞士宝盟Baumer中国区代理
FVDK 10N69Y0 Teach-in NPN cable, 2 m
FVDK 10N69Y0/KS35A Teach-in NPN flylead connector M8 4 pin
FVDK 10N69YR Teach-in: button / external NPN cable, 2 m
FVDK 10P69Y0 Teach-in PNP cable, 2 m
FVDK 10P69Y0/KS35A Teach-in PNP flylead connector M8 4 pin
FVDK 10P69YR Teach-in: button / external PNP cable, 2 m
FVDK 09P00Y0 - 光纤传感器和电缆 HPX-ETS
FVDK 12P6410/S35A - 光纤传感器和电缆 FVDK22
FVDK 31N06Y0 NPN cable / MIL connector HPX-ET1
FVDK 31P06Y0 PNP cable / MIL connector HPX-ET2
FVDK 31P06Y1 PNP MIL connector
FVDK 10N60Y0 Teach-in NPN cable, 2 m HPX-T1
FVDK 10N65Y0 Teach-in: button / external NPN cable, 2 m HPX-T2
FVDK 10P60Y0 Teach-in PNP cable, 2 m HPX-T3
FVDK 10P60Y0/KS35A Teach-in PNP flylead connector M8 4 pin HPX-T4
FVDK 10P65Y0 Teach-in: button / external PNP cable, 2 m
FVDK 10P65Y0/KS35A Teach-in: button / external PNP flylead connector M8 4 pin
FVDK 10N67Y2 NPN HPX-AG00-1S
FVDK 10P67Y2 PNP
FVDK 10N67YM 0,05 ... 5 ms (réglable) NPN cable, 2 m master
FVDK 10N67YS 0,05 ... 5 ms (réglable) NPN cable (output only), 2 m slave
FVDK 10P67YM 0,058 ... 5 ms (réglable) PNP cable, 2 m master
FVDK 10P67YS
FVDK 10N69YB NPN
FVDK 10P69YB PNP
FVDK 10N81Y0 240 mm 70 mm < 0,5 ms NPN cable, 2 m small hysteresis
FVDK 10N82Y0 100 mm 30 mm < 0,05 ms (Abfallzeit +0,02 ms) NPN cable, 2 m fast version
FVDK 10N83Y0 440 mm 120 mm < 0,5 ms NPN cable, 2 m high sensitivity
FVDK 10P81Y0 240 mm 70 mm < 0,5 ms PNP cable, 2 m small hysteresis
FVDK 10P81Y0/KS35A 240 mm 70 mm < 0,5 ms PNP flylead connector M8 4 pin small hysteresis
FVDK 10P82Y0 100 mm 30 mm < 0,05 ms (Abfallzeit +0,02 ms) PNP cable, 2 m fast version
FVDK 10P82Y0/KS35A 100 mm 30 mm < 0,05 ms (Abfallzeit +0,02 ms) PNP flylead connector M8 4 pin fast version
FVDK 10P83Y0 440 mm 120 mm < 0,5 ms PNP cable, 2 m high sensitivity
FVDK 10P83Y0/KS35A 440 mm 120 mm < 0,5 ms PNP flylead connector M8 4 pin high sensitivity
