´¦ÀíÆ÷ |
Intel® Core™2 Duo LV (L7400) |
ÄÚ´æ |
1 GB of DDR2-400 with ECC |
оƬ×é |
Intel® 3100 Integrated Memory Controller Hub (MCH) and I/O Controller HUB (ICH) |
ʱÖÓÆµÂÊ |
1.5 GHz |
CPU¶þ¼¶»º´æ |
4 MB |
ÒÔÌ«Íø |
Gigabit Ethernet: Dual ports on rear J2. PCIe x4 interface to host |
µç×Ó°æ |
User Flash: Socket for USB Flash Disk, Low Profile, 2.54 pitch connector, 4, 8 and 16 GB sizes available |
°åÔØFlash |
System Flash: 16 Mbits FWH Flash Memory |
Ç°Ãæ°å |
VGA-CRT 15-pin D-Sub connector (option available) |
ͼÐÎ |
64-bit 2D graphics engine on PCIe x1. Integrated 24-bit true-color RAMDAC with 230 MHz pixel clock. VGA graphics connector available as option in rugged conduction-cooled build. |
ÏÔ´æ |
32 MB of DDR2 SDRAM |
¹¦ºÄ |
Intel® Core™2 Duo at 1.5 GHz under Windows XP: 29W (idle) / 36W (100% CPU) |
RTMÖ§³Ö |
RTM Panel Connectors: Ethernet (x2), USB, Serial COM1 - RTM Onboard Connectors: SATA (x3), Serial COM2, GPIO (x2) |
ÖØÁ¿ |
Approx. 400g |
