| 主板 |
NISB3500 板载可移动 Intel® QM57 平台控制中心 支持 Intel® Core™ i7-620M PGA 处理器 (2.66GHz, 4M Cache) 支持 Intel® Core™ i5-520M PGA 处理器 (2.4GHz, 3M Cache) Support Intel® P4500 PGA Processor (1.86GHz, 2M Cache)
| 内存 |
2x 240-pin DIMM 内存,可达 4GB DDR3 800/1066MHz SDRAM, 无缓冲, non-ECC * Note: Actual memory size is dynamic based on the OS I/O resource allocation
| I/O 接口-前面板 |
ATX power on/off switch HDD Access/Power status LEDs 2 x USB2.0 ports 2 x eSATA ports 3 x IEEE1394b ports 1 x HDMI
| I/O 接口-后面板 |
2-pin Remote Power on/ff switch 9~30V DC input 1 x PS/2 for Keyboard / Mouse 1 x DB15 male connector for GPIO (4x digital-input and 4x digital-output) 1 x DB44 Serial Port for 4x RS232 (COM2: RS232/422/485 with auto fl ow control) 2x GbE LAN ports 4 x USB2.0 ports 1 x DB15 VGA port 1 x DVI-I port 1 x Speaker-out and 1x Mic-in
| 设置 |
2 x 2.5" HDD driver bay
| 扩展 |
1 x PCI expansion (Max. power consumption= 10w/ slot) 1 x PCIe expansion (Max. power consumption= 10w/ slot) Add-on card length: 169mm max.
| 电源要求 |
ATX 电源模块 板载直流电源设计,支持9V~30V DC 电源适配器可选
| 规格尺寸 |
195mm (W) x 268 mm (D) x 101mm (H) (7.7" x 10.5" x 3.98")
| 构造 |
无风扇铝制机壳设计
| 环境温度 |
操作温度: Ambient with air flow: -5°C ~ 55°C (According to IEC60068-2-1, IEC60068-2-2, IEC60068-2-14) 存储温度: -20°C ~ 80°C 相对湿度: 10% to 93% (Non-Condensing)
| 通过认证 |
EN60601 Compliant CE approval FCC Class B |
