产品名称:
EBC 360 3.5”CPU主板
型 号:
EBC 360
价 格:
0.00
品 牌:
EBC 3603.5" On-board Intel® SoC Tolapai 1200/600MHz CPU with 2 x CAN Bus/2 x Gigabit LAN/1 x SATA/1 x IEEE 1394
- 主要特点
- Support Intel® Embedded SoC Tolapai processor 1200/600 MHz with 256KB L2 cache
- Intel® Tolapai SoC integrated MCH and ICH only support CRT display
- 1 x SO-DIMM socket to support DDR2 400/533/667/800 SDRAM
- XGI Volari Z11 Graphic chipset with DDR2 SDRAM and VGA BIOS auto memory size detection
- 2 x CAN bus ports via pin-header
- USB 2.0 x 4, Serial port x 2, SATA x 1
- 1 x IEEE 1394
产品型录(PDF) 下载
The EBC 360 is a 3.5" board with an on-board Intel® System-on-Chip Tolapai processor 1200/600MHz with 256KB L2 cache. The EBC 360 embedded board features CAN bus to apply around at so many fields, like factory automation, car industry, marine control, medical system, photo-copiers and aircraft control as well.
The integrated MCH provides two GbE LAN ports and integrated XGI Volari Z11 Graphic chipset for CRT display. The 3.5" board EBC 360 features a CAN bus single computer board to reduce versatile converter board and less cabling on all controller area network applications.
产品规格:
| CPU |
Support Intel® Embedded SoC Tolapai processor 1200/600 MHz with 256KB L2 cache |
| 内存 |
1 x 200-pin SO-DIMM socket, support up to 1 GB non-ECC 400/533/667/800 DDR2 SDRAM Note: DDR2 800 is only supported by processor 1200 MHz |
| 芯片组 |
Intel® Integrated SoC MCH Intel® Integrated SoC ICH |
| BIOS |
Award system BIOS Plug & Play support Advanced Power Management Advanced Confi guration & Power Interface 8M bits SPI ROM |
| 板载 LAN |
Embedded Marvell PHY Controller 88E1111 single port x 2 via pin header Support Wake on LAN (When 5Vsb power available) |
| Display |
Integrated graphic engine by XGI Volari Z11 GPU with DDR2 SDRAM through PCIe 1x Interface 230MHz pixel clock support CRT display up to 1600x1200@70Hz 16M colors |
| 扩展 |
1 x PCI104 slot |
| I/O 接口 |
2 x CAN bus ports, pin-header Serial port: 2 port, 2x5 2.0mm Box header, RS232 only USB 2.0: 4 ports, 2 ports edge connector, 2 ports by JST connector 8 GPIO lines via header (GPI 0~3 and GPO 0~3), CMOS Level (0/+3.3V) On-board Power LED and HDD Active LED Pin Header 1 x 3-pin fan connector (for CPU or System) 1 x PS/2 Keyboard/Mouse via pin header On board Buzzer / SMBus2.0 /Power SW/Reset SW IEEE 1394 via pin header |
| 看门狗时钟 |
Watchdog timeout can be programmable by Software from 1 sec to 10 mins (Tolerance 15% under room temp. 25°C) from Tolapai |
| 存储设置 |
1 x SATA 插槽 |
| 系统监视器 |
Monitoring of 3 Voltages, 2 Temperature and 1 Fans Speed (From IT8512E) 3 Voltage (For +3.3V, +5V, Vcore) 2 Temperatures (CPU, System) 2 Fan speed (CPU or System Fan.) |
| 板载 RTC |
内嵌RTC电池备份 1个外部锂电池 |
| 电源需求 |
支持AT/ATX 模式 +12V/+5V/+V5sb Power In Power Type (Voltage)+12V, +5V, +5Vsb; Currents (Ampere) 3.5A, 17.06A, 1.05A |
| 尺寸规格 |
3.5" form factor, 146 mm (L) x 105 mm (W) (5.7" x 4.1") |
| 环境 |
操作温度: 0°C ~ 60°C 存储温度: -20˚C ~ 85˚C 相对湿度: 操作 10%~90%, 无凝露 |
| 认证 |
CE approval FCC Class A |
