Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú µçÔ´¿ØÖÆÆ÷
²úÆ·Ãû³Æ£º µçÔ´¿ØÖÆÆ÷
ÐÍ ºÅ£º TU1451
Æ· ÅÆ£º 322
The TU Series quad units with four independent electrically isolated single phase SCR assemblies mounted on a space saving heatsink are available in four versions. They address the needs of simple resistive and complex loads with communications. These units handle loads from 25A¨C125A per channel, up to 500Vac. They may be used with the model 260 Diagnostic Unit
TU1450/TU1470 The TU1450 is a communicating small frame quad unit available in a 25A or 40A rating as a time proportioned SCR for simple resistive loads. It includes front panel LED's and optional load current measurement.
¹«Ë¾Ãû³Æ£º ´óÁ¬°®¿ËÐÂÒÇÆ÷ÓÐÏÞ¹«Ë¾
µç »°£º 0411 82650498-806 / À
ÊÖ»ú£º
µØ Ö·£º ´óÁ¬Êиʾ®×ÓÇø»ãÈʽÖÔ¶Ñó¹ã³¡15ºÅ101ÊÒ
ÓÊ ±à£º 116033
Ö÷ Ò³£º http://www.actioninst.com
  • ¼«ÏÞ±¨¾¯É趨Æ÷
  • ¼«ÏÞ±¨¾¯É趨Æ÷
  • TE10SµçÔ´¿ØÖÆÆ÷
  • TC3001CUP°å
  • ¹Ì̬¼ÌµçÆ÷
  • µçÔ´¿ØÖÆÆ÷
  • ÐźŸôÀëÆ÷
  • ÐźŸôÀëת»»Æ÷
  • ζȺ͹ý³Ì¿ØÖÆÆ÷
  • ŷ½ÎÂ¿ØÆ÷
