Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú µ÷¹¦Æ÷
²úÆ·Ãû³Æ£º µ÷¹¦Æ÷
ÐÍ ºÅ£º TC3001
Æ· ÅÆ£º 322
The TC3001 is a universal high performance three phase power controller for all loads from 25A-1800A/ 690V max, including resistive, inductive and temperature dependent complex loads. Self-contained units are available up to 1000A. Above this the power and control electronics are separated to extend the range up to 1800A. The TC3001 provides precision control of direct and transformer connected heaters, variable temperature coefficient elements (platinum, tungsten, molybdenum disilicide and silicon carbide), short wave infrared lamps, induction and RF heating and immersed elements for direct glass heating. All protective features of the model TC3000 are included. Special features include: 5 selectable control modes, current limit, partial load fail for resistive and infrared loads, soft start/end ramping, partial load unbalance, analog retransmission of controlled parameter and multiple status alarms. The TC3001 may be totally controlled via the communications link, simplifying wiring, saving cost. EI-Bisynch, JBus, Modbus® and Profibus® protocols are available. It may be used with the model 260 Diagnostic Unit.
¹«Ë¾Ãû³Æ£º ´óÁ¬°®¿ËÐÂÒÇÆ÷ÓÐÏÞ¹«Ë¾
µç »°£º 0411 82650498-806 / À
ÊÖ»ú£º
µØ Ö·£º ´óÁ¬Êиʾ®×ÓÇø»ãÈʽÖÔ¶Ñó¹ã³¡15ºÅ101ÊÒ
ÓÊ ±à£º 116033
Ö÷ Ò³£º http://www.actioninst.com
  • ¼«ÏÞ±¨¾¯É趨Æ÷
  • ¼«ÏÞ±¨¾¯É趨Æ÷
  • TE10SµçÔ´¿ØÖÆÆ÷
  • TC3001CUP°å
  • ¹Ì̬¼ÌµçÆ÷
  • µçÔ´¿ØÖÆÆ÷
  • ÐźŸôÀëÆ÷
  • ÐźŸôÀëת»»Æ÷
  • ζȺ͹ý³Ì¿ØÖÆÆ÷
  • ŷ½ÎÂ¿ØÆ÷
