| The TE200S is a Solid State Contactor designed for general purpose three phase applications using three wire resistive loads. Two of the three phases are switched by the TE200S, the third being directly connected. It is an ideal replacement for a mechanical or mercury contactor, accepting DC or AC logic input signals |
and giving two leg ON/OFF power switching. The TE200S is robust, compact, convenient and reliable, ideal for OEM¡¯s and users in such volume applications as plastics, heat treatment, environmental chambers and foods. |
