| The TE300 is a burst-fired SCR Power Controller with analog input designed for general purpose three phase applications for resistive loads. Switching all three legs, the TE300 may be used for three-wire loads (closed |
delta, wye without neutral), four wire loads (wye with neutral) and six wire loads (inside delta). It is also ideal for infrared loads, equipped with advanced single cycle firing. It is ideal for paint drying, environmental control, metallurgy and plastics. |
