产品名称:
SUNKWANG韩国鲜光SK-2008R,SK-2016R,SK-4012R
型 号:
价 格:
0.00
品 牌:
韩国鲜光SUN KWANG SK-2008R,SK-2016R,SK-4012R |
Model |
SK-2008R |
SK-2012R |
SK-2016R |
SK-2020R |
SK-2024R |
SK-2028R |
SK-2032R |
SK-2036R |
SK-2040R |
Transmitter |
ST-2008R |
ST-2012R |
ST-2016R |
ST-2020R |
ST-2024R |
ST-2028R |
ST-2032R |
ST-2036R |
ST-2040R |
Receiver |
SR-2008R |
SR-2012R |
SR-2016R |
SR-2020R |
SR-2024R |
SR-2028R |
SR-2032R |
SR-2036R |
SR-2040R |
Dectection |
Through-beam |
Range |
7m (Max) |
Object |
Ø32mm(Min) Opaque object (Refer to the chart below right) |
No. of optical axis |
8 |
12 |
16 |
20 |
24 |
28 |
32 |
36 |
40 |
Detecting width |
140mm |
220mm |
300mm |
380mm |
460mm |
540mm |
620mm |
700mm |
780mm |
optical axis |
20mm |
Power Current consumption(Max) |
12V-24V DC±10%, Ripple 10% (Max) |
60mA |
80mA |
90mA |
100mA |
110mA |
120mA |
130mA |
140mA |
150mA |
Output mode |
NPN Open collector |
Rating |
Current output : Sink current 100mA, DC30V (Max) |
Response time |
15msec (Max) |
Light source |
Infrared LED, Wave-length 95mm |
sensing cell |
Photo-transistor |
LED indicator |
Transmitter : Power indicator (Green LED, Red LED) Receiver : Stability indicator (Green LED), Operation indicator (Red LED) |
Incidental Function |
Built-in Output short circuit protection, discontinuity of transfer line protection and function preventing interference when installing in parallel. |
Material |
Case : Aluminum, Front cover and Lens : Acrylic |
Connection |
Connector 0.5sq X 4, Output dia.Ø6.0, 0.3m length, With 4 pins in the connector(*) |
Weight (max) |
Trns |
192g |
245g |
285g |
340g |
390g |
445g |
485g |
540g |
580g |
Rcvr |
192g |
245g |
285g |
340g |
390g |
445g |
485g |
540g |
580g |
Notes |
* All models has a PNP output type. |
MODEL |
A |
B |
C |
D |
SK - 4004R |
235 |
215 |
179 |
114 |
SK - 4006R |
334 |
314 |
221 |
190 |
SK - 4008R |
410 |
390 |
321 |
266 |
SK - 4010R |
486 |
466 |
379 |
342 |
SK - 4012R |
562 |
542 |
479 |
418 |
SK - 4014R |
638 |
618 |
521 |
494 |
SK - 4016R |
714 |
694 |
621 |
570 |
SK - 4018R |
790 |
770 |
679 |
646 |
SK - 4020R |
866 |
846 |
779 |
722 |
SK - 4022R |
942 |
922 |
821 |
798 |
SK - 4024R |
1018 |
998 |
921 |
874 |
