产品名称:
台湾瑞科SN10-N,SN20-KP2,SN10-KP2
型 号:
价 格:
品 牌:
台湾瑞科RIKO SN20-KP2接近开关,台湾瑞科RIKO SN20-KP2接近开关,台湾瑞科RIKO SN20-KP2接近开关
Output mothod 輸出模式 |
NPN N.O. |
SN10-N |
SN10-NK |
NPN N.C. |
SN10-N2 |
SN10-N2K |
PNP N.O. |
SN10-P |
SN10-PK |
PNP N.C. |
SN10-P2 |
SN10-P2K |
NPN N.O./N.C. PNP N.O./N.C. |
SN10-KP2 |
SCR N.O. |
SN10-A |
SCR N.C. |
SN10-A2 |
Sensing surface / 檢測方向 |
Top surface / 前方 |
Top surface / 前方 |
Standard sensing object / 標準檢測物 |
Iron 30 x 30 x 1mm |
Sensing distance / 檢出距離 |
10 mm |
10 mm |
Secure sensing distance / 建議距離 |
0 to 8 mm |
0 to 8 mm |
Hysteresis / 遲滯 |
≦ 10 % of sensing distance |
Response time / 反應時間 |
3.3 ms Max. |
50 ms Max. |
Operating voltage / 工作電壓 |
DC10 ~ 30 V |
AC90 ~ 260 V |
Current consumption / 消耗電流 |
8 mA Max. |
2 mA Max. |
Load current / 負載電流 |
100 mA Max. at DC30V |
5~300 mA Max. |
Leakage current / 漏電流 |
≦ 1.1mA no-load |
≦ 2.0mA no-load |
Residual voltage / 殘餘電壓 |
≦DC 1.5V |
≦ AC 4V |
Insulation resistance / 隔離阻抗 |
20M Ω min. (DC500V) |
Voltage withstandability / 絕緣耐壓 |
AC1000V 60Hz for 60 Sec. |
Operating temperature / 工作溫度範圍 |
-20℃ ~ + 60℃ |
-20℃ ~ + 60℃ |
Protection degree / 防水等級 |
IP 66 |
IP 66 |
Wiring method / 出線方式 |
Pre-wired Ø5.2 x 2M/3-wires (KP2:Ø5.2 x 2M/4 wires) |
M12 pigtailed type /M12 接頭15cm電線式 |
Pre-wire Ø5.2 x 2M/2-wires |
Weight / 重量 |
Approx. 125g |
Approx. 70g |
Approx. 125g |
規格表 |
NPN N.O. |
SN20-N |
SN20-NK |
NPN N.C. |
SN20-N2 |
SN20-N2K |
PNP N.O. |
SN20-P |
SN20-PK |
PNP N.C. |
SN20-P2 |
SN20-P2K |
SN20-KP2 |
SCR N.O. |
SN20-A |
SCR N.C. |
SN20-A2 |
Top surface / 前方 |
Top surface / 前方 |
Iron 40 x 40 x 1mm |
20 mm |
20 mm |
0 to 16 mm |
0 to 16 mm |
Hysteresis / 遲滯 |
20 ms Max. |
50 ms Max. |
DC10 ~ 30 V |
AC90 ~ 260 V |
8 mA Max. |
2 mA Max. |
5~300 mA Max. |
≦ 1.1mA no-load |
≦ 2.0mA no-load |
≦DC 1.5V |
≦ AC 4V |
-20℃ ~ + 60℃ |
-20℃ ~ + 60℃ |
IP 66 |
IP 66 |
Weight / 重量 |
Approx. 170g |
Approx. 118g |
Approx. 170g | |
