免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → 日本竹中光纤线FU901BC,FU712BC
产品名称: 日本竹中光纤线FU901BC,FU712BC
型 号: FU901BC,FU712BC
价 格:
品 牌: 189
日本竹中光纤线FU901BC
FU505BC 15.000 光軸調整不要
振動に強い
7 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''''''''''''''''unit%2FFU505BC_j.htm''''''''''''''''%2C''''''''''''''''''''''''''''''''%2C''''''''''''''''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'''''''''''''''')%22">外形寸法図
FU712BC 9.000 12 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''''''''''''''''unit%2FFU712BC_j.htm''''''''''''''''%2C''''''''''''''''''''''''''''''''%2C''''''''''''''''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'''''''''''''''')%22">外形寸法図
FU715BC 10.000 15 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''''''''''''''''unit%2FFU715BC_j.htm''''''''''''''''%2C''''''''''''''''''''''''''''''''%2C''''''''''''''''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'''''''''''''''')%22">外形寸法図
FU725BC 9,000 25 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''''''''''''''''unit%2FFU725BC_j.htm''''''''''''''''%2C''''''''''''''''''''''''''''''''%2C''''''''''''''''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'''''''''''''''')%22">外形寸法図
FU904BC 12.000 4光軸
16光軸
12 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''''''''''''''''unit%2FFU904BC_j.htm''''''''''''''''%2C''''''''''''''''''''''''''''''''%2C''''''''''''''''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'''''''''''''''')%22">外形寸法図
FU916BC 15,000 30 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''''''''''''''''unit%2FFU916BC_j.htm''''''''''''''''%2C''''''''''''''''''''''''''''''''%2C''''''''''''''''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'''''''''''''''')%22">外形寸法図
VRF-N,VRF-SN2光纤放大器
额定电源
12 to 24VDC ±10%(Ripple P-P :Max.10%)
电流消耗
最大40mA
最大45mA
使用光源
红发光二极管(调制)
灵敏度
2种调节装置(粗调,细调)
自动调节
动作方式
通过控制线选择Dark ON 和Light ON方式
自动设置Dark ON 和Light ON方式
控制输出
NPN universal output :-->负载电压:30V,负载电流:最大.200mA,残留电压:最大.1V
保护电路
反极性保护,短路保护
指示灯
动作指示:红色LED
STAB:目标物在稳定的探测区内时绿色指示灯点亮,输出时:红色灯亮
连接
电缆连接
绝缘电阻
20MΩ Min ( 500VDC )
抗干扰
power line ±240V at pulse band 1us of noise simulation
耐电压
1000VAC 50/60Hz 一分钟
抗振动
10 to 55Hz (周期每分鐘 )复振幅1.5mm X、Y、Z各方向2小時
抗冲击
 500M/S2( 50G ) X、Y、Z各方向3次
环境照度
太阳光:11,000 Lux.Max.,日光灯:3,000 Lux. Max.
环境温度
使用时 : -10 to +60℃( 未結冰狀態下 )
储存时 : -25 to +70℃ (未結冰狀態下 )
环境湿度
使用時 : 35 to 85% RH
存储時 : 35 to 85% RH
材料
外壳:ABS,
外壳:
电缆
4P, Φ 5mm,长度:2m
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
