免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → 科瑞DW-AD-621-M8-122,DW-AD-611-M12接近开关
产品名称: 科瑞DW-AD-621-M8-122,DW-AD-611-M12接近开关
型 号: DW-AD-621-M8-122
价 格:
品 牌:
台湾阳明圆柱型接近开关产品选型 圆形接近开关PM12-02N,PM12-04N,PM12-02P现货优价
型号
输出状态
输出方式
工作电压
感应距离
反应频率
安装方式
PM08-01N
NO
NPN
10~30VDC
1.0mm
2.5KHZ
Flushed
PM08-01NB
NC
NPN
PM08-01P
NO
PNP
PM08-01PB
NC
PNP
PM12-02N
NO
NPN
10~30VDC
2.0mm
2.5KHZ
Flushed
PM12-02NB
NC
NPN
PM12-02P
NO
PNP
PM12-02PB
NC
PNP
PM12-02N-S
NO
NPN
10~30VDC
2.0mm
2.5KHZ
Flushed
PM12-02NB-S
NC
NPN
PM12-02P-S
NO
PNP
PM12-02PB-S
NC
PNP
PM12-04N-S
NO
NPN
10~30VDC
4.0mm
2.5KHZ
Non-Flushed
PM12-04NB-S
NC
NPN
PM12-04P-S
NO
PNP
PM12-04PB-S
NC
PNP
PM12-02N
NO
NPN
10~30VDC
2.0mm
2.5KHZ
Flushed
PM12-02NB
NC
NPN
PM12-02P
NO
PNP
PM12-02PB
NC
PNP
PM12-04N
NO
NPN
10~30VDC
4.0mm
2.5KHZ
Non-Flushed
PM12-04NB
NC
NPN
PM12-04P
NO
PNP
PM12-04PB
NC
PNP
PM12-02S
NO
SCR
90~250VAC
2.0mm
20HZ
Flushed
PM12-02SB
NC
SCR
PM12-04S
NO
SCR
90~250VAC
4.0mm
20HZ
Non-Flushed
PM12-04SB
NC
SCR
PM18-05N
NO
NPN
10~30VDC
5.0mm
2.5KHZ
Flushed
PM18-05NB
NC
NPN
PM18-05P
NO
PNP
PM18-05PB
NC
PNP
PM30-10N-S
NO
NPN
10~30VDC
10.0mm
500KHZ
Flushed
PM30-10NB-S
NC
NPN
PM30-10P-S
NO
PNP
PM30-10PB-S
NC
PNP
PM30-15N-S
NO
NPN
10~30VDC
15.0mm
500KHZ
Non-Flushed
PM30-15NB-S
NC
NPN
PM30-15P-S
NO
PNP
PM30-15PB-S
NC
PNP
PM30-10S
NO
SCR
90~250VAC
10.0mm
20HZ
Flushed
PM30-10SB
NC
SCR
PM30-15S
NO
SCR
90~250VAC
15.0mm
20HZ
Non-Flushed
PM30-15SB
NC
SCR
科瑞接近开关产品系列 DW-AD-301-03 DW-AD-621-N4 DW-AD-501-M5 DW-AD-503-M5 DW-AD-422-065-400 DW-AS-601-065-001 DW-AS-622-065-129 DW-AD-631-065 DW-AS-601-M8-123 DW-AD-621-M8 DW-AD-302-03 DW-AD-622-M4 DW-AD-502-M5 DW-AD-504-M5 DW-AD-423-065-400 DW-AS-602-065-001 DW-AS-623-065-129 DW-AD-632-065 DW-AS-602-M8-123 DW-AD-622-M8 DW-AD-303-03 DW-AD-623-M4 DW-AD-501-04 DW-AS-501-M5 DW-AD-424-065-400
DW-AD-304-03 DW-AD-624-M4 DW-AD-502-04 DW-AS-502-M5 DW-AD-425-065-400 DW-AS-604-065-001 DW-AS-621-065-123 DW-AD-634-065 DW-AS-604-M8-123 DW-AD-624-M8 DW-AD-305-03 DW-AV-621-M4-276 DW-AD-503-04 DW-AS-503-M5 DW-AD-601-065-121 DW-AS-601-065 DW-AS-622-065-123 DW-AS-631-065-001 DW-AS-601-M8-124 DW-AS-621-M8-129 DW-AV-301-03-276 DW-AV-622-M4-276 DW-AD-504-04 DW-AS-504-M5 DW-AD-602-065-121 DW-AS-602-065 DW-AS-623-065-123 DW-AS-632-065-001 DW-AS-602-M8-124 DW-AS-622-M8-129 DW-AV-302-03-276 DW-AV-623-M4-276 DW-AS-501-04 DW-AD-401-C5 DW-AD-603-065-121 DW-AS-603-065 DW-AS-624-065-129 DW-AS-633-065-001 DW-AS-603-M8-124 DW-AS-623-M8-129 DW-AV-303-03-276 DW-AV-624-M4-276 DW-AS-502-04 DW-AD-402-C5 DW-AD-604-065-121 DW-AS-604-065 DW-AS-621-065-124 DW-AS-634-065-001 DW-AS-604-M8-124 DW-AS-624-M8-129 DW-AV-304-03-276 DW-AD-401-04 DW-AS-503-04 DW-AD-403-C5 DW-AD-601-065-122 DW-AD-621-065-120 DW-AS-622-065-124 DW-AS-603080-168 DW-AS-601-M8-001 DW-AS-621-M8-123 DW-AS-305-03 DW-AD-402-04 DW-AS-504-04 DW-AD-404-C5 DW-AD-602-065-122 DW-AD-622-065-120 DW-AS-623-065-124 DW-AV-623-080-236 DW-AS-602-M8-001 DW-AS-622-M8-123 DW-AD-621-03 DW-AD-403-04 DW-AD-401-M5 DW-AD-405-C5 DW-AD-603-065-122 DW-AD-623-065-120 DW-AS-624-065-124 DW-AD-421-M8 DW-AS-603-M8-001 DW-AS-623-M8-123 DW-AD-622-03 DW-AD-404-04 DW-AD-402-M5 DW-AV-401-C5-276 DW-AD-604-065-122 DW-AD-624-065-120 DW-AS-621-065-001 DW-AD-422-M8 DW-AS-604-M8-001 DW-AS-624-M8-123 DW-AD-623-03 DW-AD-405-04 DW-AD-403-M5 DW-AV-402-C5-276 DW-AD-601-065 DW-AD-621-065-400 DW-AS-622-065-001 DW-AD-423-M8 DW-AS-601-M8-120 DW-AS-621-M8-124 DW-AD-624-03 DW-AV-403-04-236 DW-AD-404-M5 DW-AV-403-C5-276 DW-AD-602-065 DW-AD-622-065-400 DW-AS-623-065-001 DW-AD-424-M8 DW-AS-603-M8-120 DW-AS-622-M8-124 DW-AV-621-03-276 DW-AV-404-04-236 DW-AD-405-M5 DW-AV-404-C5-276 DW-AD-603-065 DW-AD-623-065-400 DW-AS-624-065-001 DW-AD-425-M8 DW-AS-601-M8 DW-AS-623-M8-124 DW-AV-622-03-276 DW-AS-401-04 DW-AS-401-M5 DW-AS-405-C5 DW-AD-604-065 DW-AD-624-065-400 DW-AD-621-065 DW-AD-601-M8-121 DW-AS-602-M8 DW-AS-624-M8-124 DW-AV-623-03-276 DW-AS-402-04 DW-AS-402-M5 DW-AD-621-C5 DW-AS-421-065-001 DW-AD-621-065-121 DW-AD-622-065 DW-AD-602-M8-121 DW-AS-603-M8 DW-AS-621-M8-001 DW-AV-624-03-276 DW-AS-403-04 DW-AS-403-M5 DW-AD-622-C5 DW-AS-422-065-001 DW-AD-622-065-121 DW-AD-623-065 DW-AD-603-M8-121 DW-AS-604-M8 DW-AS-622-M8-001 DW-AD-301-M4 DW-AS-404-04 DW-AS-404-M5 DW-AD-623-C5 DW-AS-423-065-001 DW-AD-623-065-121 DW-AD-624-065 DW-AD-604-M8-121 DW-AD-621-M8-120 DW-AS-623-M8-001 DW-AD-302-M4 DW-AS-405-04 DW-AS-405-M5 DW-AD-624-C5 DW-AS-424-065-001 DW-AD-624-065-121 DW-AD-501-065 DW-AD-601-M8-122 DW-AD-622-M8-120 DW-AS-624-M8-001 DW-AD-303-M4 DW-AD-405-04K DW-AD-621-M5 DW-AV-621-C5-276 DW-AS-425-065-001 DW-AD-621-065-122 DW-AD-502-065 DW-AD-602-M8-122 DW-AD-623-M8-120 DW-AS-621-M8 DW-AD-304-M4 DW-AD-621-04 DW-AD-622-M5 DW-AV-622-C5-276 DW-AS-601-065-123 DW-AD-622-065-122 DW-AD-503-065 DW-AD-603-M8-122 DW-AD-624-M8-120 DW-AS-622-M8 DW-AD-305-M4 DW-AD-622-04 DW-AD-623-M5 DW-AV-623-C5-276 DW-AS-602-065-123 DW-AD-623-065-122 DW-AD-504-065 DW-AD-604-M8-122 DW-AD-621-M8-121 DW-AS-623-M8 DW-AV-301-M4-276 DW-AD-623-04 DW-AD-624-M5 DW-AD-421-065 DW-AS-603-065-123 DW-AD-624-065-122 DW-AS-501-065-001 DW-AD-601-M8 DW-AD-622-M8-121 DW-AS-624-M8 DW-AV-302-M4-276 DW-AD-624-04 DW-AS-621-M5 DW-AD-422-065 DW-AS-604-065-123 DW-AD-621-065 DW-AS-502-065-001 DW-AD-602-M8 DW-AD-623-M8-121 DW-AS-621-M8-193 DW-AV-303-M4-276 DW-AS-621-04 DW-AS-622-M5 DW-AD-423-065 DW-AS-601-065-124 DW-AD-622-065 DW-AS-503-065-001 DW-AD-603-M8 DW-AD-624-M8-121 DW-AS-622-M8-193 DW-AV-304-M4-276 DW-AS-622-04 DW-AS-623-M5 DW-AD-424-065 DW-AS-602-065-124 DW-AD-623-065 DW-AS-504-065-001 DW-AD-604-M8 DW-AD-621-M8-122 DW-AS-623-M8-193 DW-AS-305-M4 DW-AS-623-04 DW-AS-624-M5 DW-AD-425-065 DW-AS-603-065-124 DW-AD-624-065 DW-AS-501-065 DW-AS-421-M8-001 DW-AD-622-M8-122 DW-AS-624-M8-193 DW-AS-624-04 DW-AD-421-065-400 DW-AS-604-065-124 DW-AS-621-065-129 DW-AS-502-065 DW-AS-422-M8-001 DW-AD-623-M8-122 DW-AD-611-M8-121 DW-AS-503-065 DW-AS-423-M8-001 DW-AD-624-M8-122 DW-AD-612-M8-121 DW-AS-504-065 DW-AS-424-M8-001 DW-AD-613-M8-121 DW-AS-425-M8-001 DW-AD-614-M8-121 DW-AD-611-M8-122 DW-AS-701-M8-001 DW-AS-711-M8-001 DW-AS-601-M12-120 DW-AD-621-M12-120 DW-AD-701-M12 DW-AS-711-M12 DW-AD-617-M18 DW-AD-601-M30-120 DW-AS-611-M30-002 DW-AD-612-M8-122 DW-AS-702-M8-001 DW-AS-712-M8-001 DW-AS-602-M12-120 DW-AD-622-M12-120 DW-AD-702-M12 DW-AS-712-M12 DW-AD-618-M18 DW-AD-602-M30-120 DW-AS-612-M30-002 DW-AD-613-M8-122 DW-AS-703-M8-001 DW-AS-713-M8-001 DW-AS-603-M12-120 DW-AD-623-M12-120 DW-AD-703-M12 DW-AS-713-M12 DW-AS-611-M18-120 DW-AD-603-M30-120 DW-AS-613-M30-002 DW-AD-614-M8-122 DW-AS-704-M8-001 DW-AS-714-M8-001 DW-AS-604-M12-120 DW-AD-624-M12-120 DW-AD-704-M12 DW-AS-714-M12 DW-AS-612-M18-120 DW-AD-604-M30-120 DW-AS-614-M30-002 DW-AD-611-M8 DW-AD-521-M8 DW-AD-601-C8 DW-AS-605-M12-120 DW-AD-625-M12-120 DW-AS-701-M12 DW-AD-601-M18-120 DW-AS-613-M18-120 DW-DD-605-M30-120 DW-DS-615-M30-002 DW-AD-612-M8 DW-AD-522-M8 DW-AD-602-C8 DW-AS-606-M12-120 DW-AD-626-M12-120 DW-AS-702-M12 DW-AD-602-M18-120 DW-AS-614-M18-120 DW-DD-606-M30-120 DW-DS-616-M30-002 DW-AD-613-M8 DW-AD-523-M8 DW-AD-603-C8 DW-AS-601-M12 DW-AD-621-M12 DW-AS-703-M12 DW-AD-603-M18-120 DW-DS-615-M18-120 DW-AD-601-M30 DW-AS-617-M30-002 DW-AD-614-M8 DW-AD-524-M8 DW-AD-604-C8 DW-AS-602-M12 DW-AD-622-M12 DW-AS-704-M12 DW-AD-604-M18-120 DW-DS-616-M18-120 DW-AD-602-M30 DW-AS-618-M30-002 DW-AS-611-M8-123 DW-AS-521-M8-001 DW-AS-601-C8-001 DW-AS-603-M12 DW-AD-623-M12 DW-AD-521-M12 DW-AD-605-M18-120 DW-AS-611-M18-002 DW-AD-603-M30 DW-AD-701-M30 DW-AS-612-M8-123 DW-AS-522-M8-001 DW-AS-602-C8-001 DW-AS-604-M12 DW-AD-624-M12 DW-AD-522-M12 DW-AD-606-M18-120 DW-AS-612-M18-002 DW-AD-604-M30 DW-AD-702-M30 DW-AS-613-M8-123 DW-AS-523-M8-001 DW-AS-603-C8-001 DW-AS-605-M12 DW-AD-625-M12 DW-AD-523-M12 DW-AD-601-M18 DW-AS-613-M18-002 DW-DD-605-M30 DW-AD-703-M30 DW-AS-614-M8-123 DW-AS-524-M8-001 DW-AS-604-C8-001 DW-AS-606-M12 DW-AD-626-M12 DW-AD-524-M12 DW-AD-602-M18 DW-AS-614-M18-002 DW-DD-606-M30 DW-AD-704-M30 DW-AS-611-M8-124 DW-AS-521-M8 DW-AD-621-C8 DW-AS-607-M12-069 DW-AS-621-M12-120 DW-AS-521-M12 DW-AD-603-M18 DW-DS-615-M18-002 DW-AD-607-M30 DW-AS-701-M30-002 DW-AS-612-M8-124 DW-AS-522-M8 DW-AD-622-C8 DW-AS-608-M12-069 DW-AS-622-M12-120 DW-AS-522-M12 DW-AD-604-M18 DW-DS-616-M18-002 DW-AD-608-M30 DW-AS-702-M30-002 DW-AS-613-M8-124 DW-AS-523-M8 DW-AD-623-C8 DW-AD-611-M12-120 DW-AS-623-M12-120 DW-AS-523-M12 DW-DD-605-M18 DW-AS-617-M18-002 DW-AS-601-M30-120 DW-AS-703-M30-002 DW-AS-614-M8-124 DW-AS-524-M8 DW-AD-624-C8 DW-AD-612-M12-120 DW-AS-624-M12-120 DW-AS-524-M12 DW-DD-606-M18 DW-AS-618-M18-002 DW-AS-602-M30-120 DW-AS-704-M30-002 DW-AS-611-M8-001 DW-AD-631-M8 DW-AS-621-C8-001 DW-AD-613-M12-120 DW-AS-625-M12-120 DW-AD-511-M12-120 DW-AD-607-M18 DW-AD-621-M18-120 DW-AS-603-M30-120 DW-AD-501-M30-120 DW-AS-612-M8-001 DW-AD-632-M8 DW-AS-622-C8-001 DW-AD-614-M12-120 DW-AS-626-M12-120 DW-AD-512-M12-120 DW-AD-608-M18 DW-AD-622-M18-120 DW-AS-604-M30-120 DW-AD-502-M30-120 DW-AS-613-M8-001 DW-AD-633-M8 DW-AS-623-C8-001 DW-DD-615-M12-120 DW-AS-621-M12 DW-AD-513-M12-120 DW-AS-601-M18-120 DW-AD-623-M18-120 DW-DS-605-M30-120 DW-AD-503-M30-120 DW-AS-614-M8-001 DW-AD-634-M8 DW-AS-624-C8-001 DW-DD-616-M12-120 DW-AS-622-M12 DW-AD-514-M12-120 DW-AS-602-M18-120 DW-AD-624-M18-120 DW-DS-606-M30-120 DW-AD-504-M30-120 DW-AS-611-M8 DW-AS-631-M8-001 DW-AD-501-C8 DW-AD-611-M12 DW-AS-623-M12 DW-AD-511-M12 DW-AS-603-M18-120 DW-DD-625-M18-120 DW-AS-601-M30-002 DW-AD-501-M30 DW-AS-612-M8 DW-AS-632-M8-001 DW-AD-502-C8 DW-AD-612-M12 DW-AS-624-M12 DW-AD-512-M12 DW-AS-604-M18-120 DW-DD-626-M18-120 DW-AS-602-M30-002 DW-AD-502-M30 DW-AS-613-M8 DW-AS-633-M8-001 DW-AD-503-C8 DW-AD-613-M12 DW-AS-625-M12 DW-AD-513-M12 DW-DS-605-M18-120 DW-AD-621-M18 DW-AS-603-M30-002 DW-AD-503-M30 DW-AS-614-M8 DW-AS-634-M8-001 DW-AD-504-C8 DW-AD-614-M12 DW-AS-626-M12 DW-AD-514-M12 DW-DS-606-M18-120 DW-AD-622-M18 DW-AS-604-M30-002 DW-AD-504-M30 DW-AD-501-M8 DW-AD-511-M8 DW-AS-501-C8 DW-DD-615-M12 DW-AD-501-M12-120 DW-AS-511-M12-120 DW-AS-601-M18-002 DW-AD-623-M18 DW-DS-605-M30-002 DW-AS-501-M30-120 DW-AD-502-M8 DW-AD-512-M8 DW-AS-502-C8 DW-DD-616-M12 DW-AD-502-M12-120 DW-AS-512-M12-120 DW-AS-602-M18-002 DW-AD-624-M18 DW-DS-606-M30-002 DW-AS-502-M30-120 DW-AD-503-M8 DW-AD-513-M8 DW-AS-503-C8 DW-AD-617-M12 DW-AD-503-M12-120 DW-AS-513-M12-120 DW-AS-603-M18-002 DW-DD-625-M18 DW-AS-607-M30-002 DW-AS-503-M30-120 DW-AD-504-M8 DW-AD-514-M8 DW-AS-504-C8 DW-AD-618-M12 DW-AD-504-M12-120 DW-AS-514-M12-120 DW-AS-604-M18-002 DW-DD-626-M18 DW-AS-608-M30-002 DW-AS-504-M30-120 DW-AS-501-M8-001 DW-AS-511-M8-001 DW-AD-601-M12-120 DW-AS-611-M12-120 DW-AD-505-M12-120 DW-AS-511-M12 DW-AS-605-M18-002 DW-AS-621-M18-120 DW-AD-611-M30-120 DW-AS-501-M30-002 DW-AS-502-M8-001 DW-AS-512-M8-001 DW-AD-602-M12-120 DW-AS-612-M12-120 DW-AD-501-M12 DW-AS-512-M12 DW-AS-606-M18-002 DW-AS-622-M18-120 DW-AD-612-M30-120 DW-AS-502-M30-002 DW-AS-503-M8-001 DW-AS-513-M8-001 DW-AD-603-M12-120 DW-AS-613-M12-120 DW-AD-502-M12 DW-AS-513-M12 DW-AS-607-M18-002 DW-AS-623-M18-120 DW-AD-613-M30-120 DW-AS-503-M30-002 DW-AS-504-M8-001 DW-AS-514-M8-001 DW-AD-604-M12-120 DW-AS-614-M12-120 DW-AD-503-M12 DW-AS-514-M12 DW-AS-608-M18-002 DW-AS-624-M18-120 DW-AD-614-M30-120 DW-AS-504-M30-002 DW-AS-501-M8 DW-AS-511-M8 DW-DD-605-M12-120 DW-DS-615-M12-120 DW-AD-504-M12 DW-AD-711-M12 DW-AD-611-M18-120 DW-DS-625-M18-120 DW-DD-615-M30-120 DW-AD-511-M30-120 DW-AS-502-M8 DW-AS-512-M8 DW-DD-606-M12-120 DW-DS-616-M12-120 DW-AS-501-M12-120 DW-AD-712-M12 DW-AD-612-M18-120 DW-DS-626-M18-120 DW-DD-616-M30-120 DW-AD-512-M30-120 DW-AS-503-M8 DW-AS-513-M8 DW-AD-601-M12-122 DW-AS-611-M12 DW-AS-502-M12-120 DW-AD-713-M12 DW-AD-613-M18-120 DW-AS-621-M18-002 DW-AD-611-M30 DW-AD-513-M30-120 DW-AS-504-M8 DW-AS-514-M8 DW-AD-602-M12-122 DW-AS-612-M12 DW-AS-503-M12-120 DW-AD-714-M12 DW-AD-614-M18-120 DW-AS-622-M18-002 DW-AD-612-M30 DW-AD-514-M30-120 DW-AD-701-M8 DW-AD-711-M8 DW-AD-603-M12-122 DW-AS-613-M12 DW-AS-504-M12-120 DW-AS-711-M12 DW-DD-615-M18-120 DW-AS-623-M18-002 DW-AD-613-M30 DW-AD-511-M30 DW-AD-702-M8 DW-AD-712-M8 DW-AD-604-M12-122 DW-AS-614-M12 DW-AS-501-M12 DW-AS-712-M12 DW-DD-616-M18-120 DW-AS-624-M18-002 DW-AD-614-M30 DW-AD-512-M30 DW-AD-703-M8 DW-AD-713-M8 DW-AD-605-M12-122 DW-AS-615-M12 DW-AS-502-M12 DW-AS-713-M12 DW-AD-611-M18 DW-DS-625-M18-002 DW-DD-615-M30 DW-AD-513-M30 DW-AD-704-M8 DW-AD-714-M8 DW-AD-606-M12-122 DW-AS-616-M12 DW-AS-503-M12 DW-AS-714-M12 DW-AD-612-M18 DW-DS-626-M18-002 DW-DD-616-M30 DW-AD-514-M30 DW-AD-607-M12-122 DW-AS-617-M12 DW-AS-504-M12 DW-AS-701-M18 DW-AD-613-M18 DW-AD-701-M18 DW-AS-611-M30-120 DW-AS-511-M30-120 DW-AD-608-M12-122 DW-AS-618-M12 DW-AS-702-M18 DW-AD-614-M18 DW-AD-702-M18 DW-AS-612-M30-120 DW-AS-512-M30-120 DW-AS-703-M18 DW-DD-615-M18 DW-AD-703-M18 DW-AS-613-M30-120 DW-AS-513-M30-120 DW-AS-704-M18 DW-DD-616-M18 DW-AD-704-M18 DW-AS-614-M30-120 DW-AS-514-M30-120 DW-DS-615-M30-120 DW-DS-616-M30-120 DW-AS-511-M30-002 DW-AD-501-P12-693 DW-AD-401-04E DW-AS-509-M18-120 DW-HD-611-M18-310 DW-LD-711-M12 DAS-0006-003 LHK-1180-301 LLS-1121L-201(R)LLS-1121L-200(E) DW-AS-512-M30-002 DW-AD-503-P12-693 DW-AD-403-04E DW-AS-509-M18-320 DW-HD-613-M18-310 DW-LD-712-M12 DAS-0010-003 LHK-1180-302 LLS-1121L-202(R)LLS-1121L-200(E) DW-AS-513-M30-002 DW-AD-501-P12-625 DW-AD-401-M5E DW-AS-509-M18-002 DW-HD-601-M30-310 DW-LD-713-M12 DAS-0015-003 LHS-1180-301 LLK-1121L-203(R)LLK-1121L-200(E) DW-AS-514-M30-002 DW-AD-503-P12-625 DW-AD-403-M5E DW-AS-509-M18-390 DW-HD-603-M30-310 DW-LD-714-M12 DAS-0020-003 LHS-1180-302 LLK-1121L-204(R)LLK-1121L-200(E) DW-AD-711-M30 DW-AD-501-P12-627 DW-AD-501-065E DW-AD-509-M30-120 DW-HD-601-M30-411 DW-LS-711-M12 DAS-0025-003 LHK-1180-303 LLS-1121L-203(R)LLS-1121L-200(E) DW-AD-712-M30 DW-AD-503-P12-627 DW-AD-503-065E DW-AD-509-M30-320 DW-HD-603-M30-411 DW-LS-712-M12 DAS-0035-003 LHK-1180-304 LLS-1121L-204(R)LLS-1121L-200(E) DW-AD-713-M30 DW-AS-501-P12-630 DW-AD-501-M8E DW-AD-509-M30 DW-HD-611-M30-310 DW-LS-713-M12 DAS-0050-003 LHS-1180-303 LLK-1180-001(R)LLK-1180-000(E) DW-AD-714-M30 DW-AS-503-P12-630 DW-AD-503-M8E DW-AD-509-M30-390 DW-HD-613-M30-310 DW-LS-714-M12 DAS-0100-003 LHS-1180-304 LLK-1180-002(R)LLK-1180-000(E) DW-AS-711-M30-002 DW-AS-501-P12-624 DW-AD-509-C8-390 DW-AS-509-M30-120 DW-HD-611-M30-411 DW-LD-701-M18 DAS-0004-003-540 LRK-1180-301 LLS-1180-001(R)LLS-1180-000(E) DW-AS-712-M30-002 DW-AS-503-P12-624 DW-AS-509-C8-390 DW-AS-509-M30-320 DW-HD-613-M30-411 DW-LD-711-M18 DAS-0006-003-540 LRK-1180-302 LLS-1180-002(R)LLS-1180-000(E) DW-AS-713-M30-002 DW-AS-501-P12 DW-AD-509-M8 DW-AS-509-M30-390 DW-HD-601-M50-300 DW-LD-712-M18 LTK-1120-301 LRS-1180-301 LLK-1180-003(R)LLK-1180-000(E) DW-AS-714-M30-002 DW-AS-503-P12 DW-AD-509-M8-390 DW-AD-519-M30-120 DW-HD-603-M50-300 DW-LD-713-M18 LTS-1120-301 LRS-1180-302 LLK-1180-004(R)LLK-1180-000(E) DW-AS-601-C44 DW-AS-504-P12 DW-AS-509-M8-001 DW-AD-519-M30-320 DW-HD-601-M50-411 DW-LD-714-M18 LTK-1120-303 LRK-1180-303 LLS-1180-003(R)LLS-1180-000(E) DW-AS-603-C44 DW-AS-501-P12-627 DW-AS-509-M8-390 DW-AD-519-M30 DW-HD-603-M50-411 DW-LS-711-M18-002 LTS-1120-303 LRK-1180-304 LLS-1180-004(R)LLS-1180-000(E) DW-AS-607-C44 DW-AS-503-P12-627 DW-AS-509-M8 DW-AD-519-M30-390 DW-HD-611-M50-300 DW-LS-712-M18-002 LRK-1120-302 LRS-1180-303 LLK-1180W-001(R)LLK-1180W-000(E) DW-AS-601-C44-304 DW-AS-501-P12-621 DW-AS-509-M8-393 DW-AS-519-M30-120 DW-HD-613-M50-300 DW-LS-713-M18-002 LRS-1120-302 LRS-1180-304 LLK-1180W-002(R)LLK-1180W-000(E) DW-AS-603-C44-304 DW-AS-503-P12-621 DW-AD-509-M12-120 DW-AS-519-M30-320 DW-HD-611-M50-411 DW-LS-714-M18002 LRK-1120-304 LLS-1180W-001(R)LLS-1180W-000(E) DW-AS-611-C44 DW-AS-501-P12-635 DW-AD-509-M12-320 DW-AS-519-M30-002 DW-HD-613-M50-411 DW-LD-711-M18 LRS-1120-304 光电对射式 LLS-1180W-002(R)LLS-1180W-000(E) DW-AS-613-C44 DW-AS-503-P12-635 DW-AD-509-M12 DW-AS-519-M30-390 DW-LD-701-M12 DW-LD-712-M18 LLK-1120-201(R)LLK-1120-200(E) LLK-1180W-003(R)LLK-1180W-000(E) DW-AS-617-C44 DW-AS-501-P12-622 DW-AD-509-M12-390 DW-HD-621-M8-100 DW-LD-702-M12 DW-LD-713-M18 LLK-1120-202(R)LLK-1120-200(E) LLK-1180W-004(R)LLK-1180W-000(E) DW-AD-601-C40 DW-AS-503-P12-622 DW-AS-509-M12-120 DW-HD-623-M8-100 DW-LD-703-M12 DW-LD-714-M18 LLS-1120-201(R)LLS-1120-200(E) LLS-1180W-003(R)LLS-1180W-000(E) DW-AD-603-C40 DW-AS-501-P18 DW-AS-509-M12-320 DW-HD-601-M12-200 DW-LD-704-M12 DW-LS-711-M18-002 LLS-1120-202(R)LLS-1120-200(E) LLS-1180W-004(R)LLS-1180W-000(E) DW-AD-607-C40 DW-AS-503-P18 DW-AS-509-M12 DW-HD-603-M12-200 DW-LS-701-M12 DW-LS-712-M18-002 LLK-1120-203(R)LLK-1120-200(E) LLK-1181L-001(R)LLK-1181L-000(E) DW-AD-613-C40 DW-AD-501-P20 DW-AS-509-M12-290 DW-HD-611-M12-200 DW-LS-702-M12 DW-LS-713-M18-002 LLK-1120-204(R)LLK-1120-200(E) LLK-1181L-002(R)LLK-1181L-000(E) DW-AD-613-C60 DW-AD-503-P20 DW-AD-509-M18-120 DW-HD-613-M12-200 DW-LS-703-M12 DW-LS-714-M18-002 LLS-1120-203(R)LLS-1120-200(E) LLS-1181L-001(R)LLS-1181L-000(E) DW-AD-613-C80 DW-AS-501-P20 DW-AD-509-M18-320 DW-HD-601-M18-310 DW-LS-704-M12 DW-LD-701-M30 LLS-1120-204(R)LLS-1120-200(E) LLS-1181L-002(R)LLS-1181L-000(E) DW-LD-711-M30 DW-AS-503-P20 DW-AD-509-M18 DW-HD-603-M18-310 DW-LD-714-M30 DW-LD-702-M30 激光对射式 LLK-1181L-003(R)LLK-1181L-000(E) DW-LD-712-M30 DW-AS-504-P20 DW-AD-509-M18-390 DW-HD-601-M18-411 DW-LS-711-M30-002 DW-LD-703-M30 LLK-1121L-201(R)LLK-1121L-200(E) LLK-1181L-004(R)LLK-1181L-000(E) DW-LD-713-M30 DW-LS-713-M30-002 DW-LS-714-M30-002 DW-HD-603-M18-411 DW-LS-712-M30-002 DW-LD-704-M30 LLK-1121L-202(R)LLK-1121L-200(E) LLS-1181L-003(R)LLS-1181L-000(E) LLS-1181L-004(R)LLS-1181L-000(E) LTK-1180-101 LHK-1180W-301 LRK-1180W-302 LTK-1180W-101 LTK-1180L-101 LTK-1180L-101-516 LLK-1181L-001/LLK-1181L-000 LTK-3030-101 LHK-3030-101 LTK-1180-102 LHK-1180W-302 LRS-1180W-302 LTK-1180W-102 LTK-1180L-102 LTK-1180L-102-516 LLK-1181L-002/LLK-1181L-000 LTK-3030-102 LHK-3030-102 LTS-1180-101 LHS-1180W-301 LRK-1180W-304 LTS-1180W-101 LTS-1180L-101 LTS-1180L-101-516 LLS-1181L-001/LLS-1181L-000 LTS-3030-101 LHS-3030-101 LTS-1180-102 LHS-1180W-302 LRS-1180W-304 LTS-1180W-102 LTS-1180L-102 LTS-1180L-102-516 LLS-1181L-002/LLS-1181L-000 LTS-3030-102 LHS-3030-102 LTK-1180-103 LHK-1180W-303 LRK-3031-302 LTK-1180W-103 LTK-1180L-103 LTK-1180L-103-516 LLK-1181L-003/LLK-1181L-000 LTK-3030-103 LHK-3030-103 LTK-1180-104 LHK-1180W-304 LRS-3031-302 LTK-1180W-104 LTK-1180L-104 LTK-1180L-104-516 LLK-1181L-004/LLK-1181L-000 LTK-3030-104 LHK-3030-104 LTS-1180-103 LHS-1180W-303 LRK-3031-304 LTS-1180W-103 LTS-1180L-103 LTS-1180L-103-516 LLS-1181L-003/LLS-1181L-000 LTS-3030-103 LHS-3030-103 LTS-1180-104 LHS-1180W-304 LRS-3031-304 LTS-1180W-104 LTS-1180L-104 LTS-1180L-104-516 LLS-1181L-004/LLS-1181L-000 LTS-3030-104 LHS-3030-104 LLK-4040-001/LLK-4040-000 LFK-4040-101 LRK-4040-101 LTK-4040-101 LTK-3031-301 LLK-3030-001/LLK-3030-000 LFK-3030-101 LRK-3030-101 LLK-4040-002/LLK-4040-000 LFK-4040-102 LRK-4040-102 LTK-4040-102 LTS-3031-301 LLK-3030-002/LLK-3030-000 LFK-3030-102 LRK-3030-102 LLS-4040-001/LLS-4040-000 LFS-4040-101 LRS-4040-101 LTS-4040-101 LTK-3031-303 LLS-3030-001/LLS-3030-000 LFS-3030-101 LRS-3030-101 LLS-4040-002/LLS-4040-000 LFS-4040-102 LRS-4040-102 LTS-4040-102 LTS-3031-303 LLS-3030-002/LLS-3030-000 LFS-3030-102 LRS-3030-102 LLK-4040-003/LLK-4040-000 LFK-4040-103 LRK-4040-103 LTK-4040-103 LHK-3031-301 LLK-3030-003/LLK-3030-000 LFK-3030-103 LRK-3030-103 LLK-4040-004/LLK-4040-000 LFK-4040-104 LRK-4040-104 LTK-4040-104 LHS-3031-301 LLK-3030-004/LLK-3030-000 LFK-3030-104 LRK-3030-104 LLS-4040-003/LLS-4040-000 LFS-4040-103 LRS-4040-103 LTS-4040-103 LHK-3031-303 LLS-3030-003/LLS-3030-000 LFS-3030-103 LRS-3030-103 LLS-4040-004/LLS-4040-000 LFS-4040-104 LRS-4040-104 LTS-4040-104 LHS-3031-303 LLS-3030-004/LLS-3030-000 LFS-3030-104 LRS-3030-104 LTK-5050-101-501 LTK-5050-101 LRK-5050-101 LLK-5050-001/LLK-5050-000 LLK-5050-001-502/LLK-5050-000-502 PTK-5555-320-3 PRK-5555-320-30-E PLK-5555-320-200-E LTK-5050-102-501 LTK-5050-102 LRK-5050-102 LLK-5050-002/LLK-5050-000 LLK-5050-002-502/LLK-5050-000-502 PTK-5555-320-3-E PRK-5555-320-40 LTS-5050-101-501 LTS-5050-101 LRS-5050-101 LLS-5050-001/LLS-5050-000 LLS-5050-001-502/LLS-5050-000-502 PTK-5555-320-10 PRK-5555-320-45-E LTS-5050-102-501 LTS-5050-102 LRS-5050-102 LLS-5050-002/LLS-5050-000 LLS-5050-002-502/LLS-5050-000-502 PTK-5555-320-E PLK-5555-320-30 LTK-5050-103-501 LTK-5050-103 LRK-5050-103 LLK-5050-003/LLK-5050-000 LLK-5050-003-502/LLK-5050-000-502 PTK-5555-320-20 PLK-5555-320-30-E LTK-5050-104-501 LTK-5050-104 LRK-5050-104 LLK-5050-004/LLK-5050-000 LLK-5050-004-502/LLK-5050-000-502 PTK-5555-320-20-E PLK-5555-320-100 LTS-5050-103-501 LTS-5050-103 LRS-5050-103 LLS-5050-003/LLS-5050-000 LLS-5050-003-502/LLS-5050-000-502 PRK-5555-320-20 PLK-5555-320-100-E LTS-5050-104-501 LTS-5050-104 LRS-5050-104 LLS-5050-004/LLS-5050-000 LLS-5050-004-502/LLS-5050-000-502 PRK-5555-320-30 PLK-5555-320-200 URS-1180C-303 UTS-1181C-303 UTS-1181C-303 URS-1181C-303 UTS-1180W-303 URS-1180W-303 URS-1181W-303 UTS-1180-303 UTS-1181-303 UTS-1180-329 UTS-1181-329 UTS-1300-303 UTS-1300-107 UTS-1301-303 UTS-1301-107 UTS-1302-303 UTS-1302-107 UTS-1303-303 UTS-1303-107 UTS-1300-123 UTS-1303-113 UTS-1303-123 UTS-1302-113 UTS-1302-123 UTS-1301-113 ITS-1301-123 UTS-1300-113
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
