¡ñ ³¬Ð¡ÐÍSATA´ÅÅÌÄ£×é ¡ñ ³¬´óÈÝÁ¿ÉýÖÁ32GB ¡ñ ¼òµ¥¡¢ÈÝÒ׵ݲװ·½Ê½ ¡ñ ÏȽø¡¢¸ïеÄÄÍÕðµÄ»úеÉè¼Æ(רÀû) ¡ñ µÚ7pin¹©µç(רÀû) ¡ñ ÌṩAES-128bitÊý¾Ý¼ÓÃÜ(SATADOM i-100)
SATADOM ϵÁÐ ¡¡¡¡InnoDisk Serial ATA Disk on Module(SATADOM)ÌṩÈÝÁ¿´Ó128MBµ½8GB¡£SATADOMÖ§³ÖSATAI±ê×¼½Ó¿Ú(1.5Gb/s)£¬¼«ºÃµÄÌá¸ßÁËÊý¾Ý´«ÊäËÙÂÊ£»Ö§³Ö¶Á24MB/s(×î´ó)¡¢Ð´14MB/s(×î´ó)¡£ Innodisk SATADOMÊÇÊÀ½çÉÏ×îСµÄ²¢ÇÒ¾ßÓжàÖÖÉè¼ÆµÄ²úÆ·¡£ÔÚSATA½Ó¿ÚµÄµÚ7pinÄÚ½¨¹©µç£»ÔÚÖ÷°åSATA¶Ë¿ÚµÚ7pinÌṩ¹©µçµÄǰÌáÏ£¬¿É²»ÐèÒª¶îÍ⹩µçÏßÀ¼´¿ÉÕý³£Ê¹Óá£ÁíÒ»¸öÐÂÓ±µÄÉè¼ÆÊÇÁ¬½ÓÍ·±¾Éí²ÉÓõ¹¹³·ÀÍÑÂ䲿¼þ£¬ÔöÇ¿ÁËÊý¾Ý´«ÊäµÄÎȶ¨ÐԺͿɿ¿ÐÔ¡£
¼¼Êõ¹æ¸ñ |
ÈÝÁ¿ |
128MB - 8GB |
½Ó¿Ú |
Serial ATA I |
IDE ´«Êäģʽ |
PIO mode0-4£¬UltraDMA mode0-2 |
¼â·åËÙ¶È |
150MB/sec |
Êý¾Ý´«ÊäËÙÂÊ |
¶Á : 24Mbytes/sec (max.) д : 14Mbytes/sec (max.) |
ϵͳ¿É¿¿ÐÔ |
ECC ¼¼Êõ |
Built-in ECC corrects up to 8-bit 512Bytes |
²»Õý³£µôµç |
´óÓÚ3,000 ´Î |
MTBF |
´óÓÚ3,000,000 hours |
ƽ¾ùдÈë |
Ö§³Ö |
Ò»°ã¼¼ÊõÒªÇó |
²Ù×÷ÎÂ¶È |
-10¡ã C ~ +70¡ã C (±ê×¼) |
´æ´¢ÎÂ¶È |
-55¡ã C ~ +195¡ã C |
ʪ¶È |
10% ~ 95%²»½á¶ |
Õ𶯠|
5G(7~2000Hz) |
³å»÷ |
50G/10ms |
µçÔ´ |
DC ÊäÈëµçѹ |
+5V single power supply operation |
¹æ¸ñ |
Íâ¿Ç |
PC mechanical cover and UL-94 |
ÍâÐγߴç |
Vertical type£º20.5x39.2x8mm(WxLxH)
Horizontal type£º18x30.3x9.15mm(WxLxH) |
| SATADOM i-100 Vertical SATADOMµç×ÓÅÌ |
| DESI-16GT21C1D |
16G SATADOM Four Channels |
| DESI-08GT21C1D |
8G SATADOM Four Channels |
| DESI-04GT21C1D |
4G SATADOM Four Channels |
| DESI-02GT21C1D |
2G SATADOM Four Channels |
| W/T SATADOM i-100 Vertical |
SATADOM¿íεç×ÓÅÌ |
| DESI-16GT21W1D |
W/T 16G SATADOM Four Channels |
| DESI-08GT21W1D |
W/T 8G SATADOM Four Channels |
| DESI-04GT21W1D |
W/T 4G SATADOM Four Channels |
| DESI-02GT21W1D |
W/T 2G SATADOM Four Channels |
| SATADOM, Vertical |
SATADOMµç×ÓÅÌ |
| DES9-08GT11C2S |
Compact SataDom, 8GB |
| DES9-04GT11C2S |
Compact SataDom, 4GB |
| DES9-02GT11C2S |
Compact SataDom, 2GB |
| DES9-01GT11C2S |
Compact SataDom, 1GB |
| DES9-512T11C2S |
Compact SataDom, 512MB |
| DES9-256T11C2S |
Compact SataDom, 256MB |
| DES9-128T11C2S |
Compact SataDom, 128GB |
| SATADOM, Vertical pin 7 w/FUSE |
SATADOM µç×ÓÅÌ |
| DES9-08GT11C2SF |
Compact SataDom, 8GB, power pin built-in |
| DES9-04GT11C2SF |
Compact SataDom, 4GB, power pin built-in |
| DES9-02GT11C2SF |
Compact SataDom, 2GB, power pin built-in |
| DES9-01GT11C2SF |
Compact SataDom, 1GB, power pin built-in |
| DES9-512T11C2SF |
Compact SataDom, 512MB, power pin built-in |
| DES9-256T11C2SF |
Compact SataDom, 256MB, power pin built-in |
| DES9-128T11C2SF |
Compact SataDom, 128GB, power pin built-in |
| SATADOM, Horizontal A type SATADOM µç×ÓÅÌ |
| DES9A-08GT11C2S |
Compact SataDom, 8GB, Horizontal A type |
| DES9A-04GT11C2S |
Compact SataDom, 4GB, Horizontal A type |
| DES9A-02GT11C2S |
Compact SataDom, 2GB, Horizontal A type |
| DES9A-01GT11C2S |
Compact SataDom, 1GB, Horizontal A type |
| DES9A-512T11C2S |
Compact SataDom, 512MB, Horizontal A type |
| DES9A-256T11C2S |
Compact SataDom, 256MB, Horizontal A type |
| DES9A-128T11C2S |
Compact SataDom, 128GB, Horizontal A type |
| SATADOM, Horizontal pin A type, 7 w/FUSE |
SATADOM µç×ÓÅÌ |
| DES9A-08GT11C2SF |
Compact SataDom, 8GB, Horizontal A type, power pin built-in |
| DES9A-04GT11C2SF |
Compact SataDom, 4GB, Horizontal A type, power pin built-in |
| DES9A-02GT11C2SF |
Compact SataDom, 2GB, Horizontal A type, power pin built-in |
| DES9A-01GT11C2SF |
Compact SataDom, 1GB, Horizontal A type, power pin built-in |
| DES9A-512T11C2SF |
Compact SataDom, 512MB, Horizontal A type, power pin built-in |
| DES9A-256T11C2SF |
Compact SataDom, 256MB, Horizontal A type, power pin built-in |
| DES9A-128T11C2SF |
Compact SataDom, 128GB, Horizontal A type, power pin built-in |
| SATADOM, Horizontal B type SATADOM µç×ÓÅÌ |
| DES9B-08GT11C2S |
Compact SataDom, 8GB, Horizontal B type |
| DES9B-04GT11C2S |
Compact SataDom, 4GB, Horizontal B type |
| DES9B-02GT11C2S |
Compact SataDom, 2GB, Horizontal B type |
| DES9B-01GT11C2S |
Compact SataDom, 1GB, Horizontal B type |
| DES9B-512T11C2S |
Compact SataDom, 512MB, Horizontal B type |
| DES9B-256T11C2S |
Compact SataDom, 256MB, Horizontal B type |
| DES9B-128T11C2S |
Compact SataDom, 128GB, Horizontal B type |
| SATADOM, Horizontal pin B type, 7 w/FUSE |
SATADOM µç×ÓÅÌ |
| DES9B-08GT11C2SF |
Compact SataDom, 8GB, Horizontal B type, power pin built-in |
| DES9B-04GT11C2SF |
Compact SataDom, 4GB, Horizontal B type, power pin built-in |
| DES9B-02GT11C2SF |
Compact SataDom, 2GB, Horizontal B type, power pin built-in |
| DES9B-01GT11C2SF |
Compact SataDom, 1GB, Horizontal B type, power pin built-in |
| DES9B-512T11C2SF |
Compact SataDom, 512MB, Horizontal B type, power pin built-in |
| DES9B-256T11C2SF |
Compact SataDom, 256MB, Horizontal B type, power pin built-in |
| DES9B-128T11C2SF |
Compact SataDom, 128GB, Horizontal B type, power pin built-in |
| W/T SATADOM, Vertical |
SATADOM ¿íεç×ÓÅÌ |
| DES9-08GT11WxS |
W/T Compact SataDom, 8GB, power pin built-in |
| DES9-04GT11WxS |
W/T Compact SataDom, 4GB, power pin built-in |
| DES9-02GT11WxS |
W/T Compact SataDom, 2GB, power pin built-in |
| DES9-01GT11WxS |
W/T Compact SataDom, 1GB, power pin built-in |
| DES9-512T11WxS |
W/T Compact SataDom, 512MB, power pin built-in |
| DES9-256T11WxS |
W/T Compact SataDom, 256MB, power pin built-in |
| DES9-128T11WxS |
W/T Compact SataDom, 128GB, power pin built-in |
